Home » Modeling » Epsilon » Problem Running Transformations
Problem Running Transformations [message #22347] Mon, 13 July 2009 19:23 Go to next message
Marcellus Castro is currently offline Marcellus CastroFriend
IŽm trying to run the examples but, always I get the same problem.
Any help will be appreciates.
org.antlr.runtime.CommonTokenStream.fillBuffer(CommonTokenSt ream.java:95)
at org.antlr.runtime.CommonTokenStream.LT(CommonTokenStream.jav a:238)
org.eclipse.epsilon.eol.AbstractModule.invokeMainRule(Abstra ctModule.java:182)
at org.eclipse.epsilon.eol.AbstractModule.parse(AbstractModule. java:142)
org.eclipse.epsilon.evl.dt.launching.EvlLaunchConfigurationD elegate.launch(EvlLaunchConfigurationDelegate.java:49)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
Re: Problem Running Transformations [message #22431 is a reply to message #22347] Mon, 13 July 2009 19:46 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Marcellus,
This happens when the program specified in the source tab of the launch
configuration does not exist. My guess is that you have imported/checked
out the examples but with different project names. You can either
re-import them using their default names, or update the launch
configurations accordingly.
In any case, it should fail more gracefully than throwing an exception,
so I'll open a new bug report to keep track of this.
Dimitris
Marcellus Castro wrote:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: Problem Running Transformations [message #22475 is a reply to message #22431] Mon, 13 July 2009 20:25 Go to previous messageGo to next message
Hi Dimitris, Thx for the answer!
I believe that the is not that. The configuration is correct but the
problem still is occurring.
Re: Problem Running Transformations [message #22519 is a reply to message #22475] Mon, 13 July 2009 20:29 Go to previous messageGo to next message
Hi Marcellus,
Which example is that? Have you checked it out from the SVN or
downloaded a .zip file?
Dimitris
Re: Problem Running Transformations [message #22563 is a reply to message #22519] Mon, 13 July 2009 20:46 Go to previous messageGo to next message
It's the validateoo example. I can run the validation only if I create a
ant task for it.
Cheers
Re: Problem Running Transformations [message #22607 is a reply to message #22563] Mon, 13 July 2009 21:10 Go to previous message
Hi Marcellus,
I can't seem to be able to reproduce this... I checked out the example
and the org.eclipse.epsilon.examples.metamodels project, registered
OO.ecore, right-clicked ValaidateOO.launch and clicked Run As ->
ValidateOO and it ran as expected. I'm starting to run low on ideas on
what may be wrong...
Dimitris
> ant task for it.
> Cheers
Re: Problem Running Transformations [message #570584 is a reply to message #22347] Mon, 13 July 2009 19:46 Go to previous message
Hi Marcellus,
Dimitris
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problem Running Transformations [message #570609 is a reply to message #22431] Mon, 13 July 2009 20:25 Go to previous message
Re: Problem Running Transformations [message #570631 is a reply to message #22475] Mon, 13 July 2009 20:29 Go to previous message
Hi Marcellus,
Dimitris
Re: Problem Running Transformations [message #570647 is a reply to message #22519] Mon, 13 July 2009 20:46 Go to previous message
ant task for it.
Cheers
Re: Problem Running Transformations [message #570671 is a reply to message #22563] Mon, 13 July 2009 21:10 Go to previous message
Hi Marcellus,
Dimitris
> ant task for it.
> Cheers
Previous Topic:Problem Running Transformations
Next Topic:Euginia: Synchronize GMF Gen Model produce an Error
Current Time: Mon Feb 26 03:51:58 GMT 2018
Powered by FUDForum. Page generated in 0.02054 seconds
