connection figure antialiasing [message #225678] |
Wed, 01 November 2006 16:25 |
Originally posted by: aleksandr_kravets.iwaysoftware.com
In GEF Logic example connections (Wires) are as not as rigid as default
PolylineConnection figures - they have some smoothness to them. I've
looked at the code but can't seem to see where this is being set. Does
anyone know how it's done?
thanks,
Alex
Re: connection figure antialiasing [message #225725 is a reply to message #225678] |
Wed, 01 November 2006 21:35 |
Aleksandr Kravets wrote:
> Hello,
> thanks,
> Alex
Ah, got it (from Logic example):
ConnectionLayer cLayer = (ConnectionLayer) getLayer(CONNECTION_LAYER);
if ((getViewer().getControl().getStyle() & SWT.MIRRORED ) == 0)
cLayer.setAntialias(SWT.ON);
Re: connection figure antialiasing [message #225741 is a reply to message #225733] |
Wed, 01 November 2006 21:47 |
David Cummings wrote:
> The Logic Diagram example enables antialiasing for its connection layer
> in the LogicDiagramEditPart#refreshVisuals method.
> David
>> Hello,
>> default PolylineConnection figures - they have some smoothness to
>> them. I've looked at the code but can't seem to see where this is
>> being set. Does anyone know how it's done?
>> thanks,
>> Alex
Right, found it in the code.
By the way
org.eclipse.gmf.runtime.draw2d.ui.figures.PolylineConnection Ex, says
that it provides smoothness and support avoid obstructions. So, does it
do similar to what Layers do in Logic example?
Alex
Re: connection figure antialiasing [message #225764 is a reply to message #225741] |
Wed, 01 November 2006 23:23 |
Xiang Qinxian Messages: 119 Registered: July 2009 |
Aleksandr Kravets 写道:
>> layer in the LogicDiagramEditPart#refreshVisuals method.
>> David
>>> Hello,
>>> thanks,
>>> Alex
> By the way
We can use directly PolylineConnectionEx in gef editor, with a similar
behavior, but newest version is best.
> Alex
By the way, For all FC6 users, setAntialias function not works in AMD64.
SWT seems no wills to resolve it in short time .
Qinxian
FUDForum. Page generated in 0.04676 seconds
