Home » Modeling » TMF (Xtext) » numeric representation too big for Integer.
numeric representation too big for Integer. [message #1300376] Thu, 17 April 2014 14:26 Go to next message
Christophe Bouhier is currently offline Christophe BouhierFriend
I need to process a numeric string which is too big to fit in an int.
A value which fails:
4294967295
This is actually the exact max size of an unsigned int, but java int is
32bit signed, so this won't fit. So I guess I need a unsigned int here.
I tried changing the return type to EBigDecimal and EBigInteger but I
still get errors/markers in the editor.
terminal INT returns ecore::EInt:
'-'? ('0'..'9')+;
Do I need to implement an IValueConverter or is there a way to handle
this in the grammar directly.?
Thank You,
Christophe
Re: numeric representation too big for Integer. [message #1300401 is a reply to message #1300376] Thu, 17 April 2014 14:49 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
yes you have to
BIG_INT returns ecore::EBigInteger:
	INT
public class MyDslConverters extends DefaultTerminalConverters {
	@Inject
	private BigIntegerValueConverter bigIntegerValueConverter;
	@ValueConverter(rule = "BIG_INT")
	public IValueConverter<BigInteger> BIG_INT() {
		return bigIntegerValueConverter;
	private static class BigIntegerValueConverter extends AbstractLexerBasedConverter<BigInteger> {
		public BigInteger toValue(String string, INode node)
				throws ValueConverterException {
			try {
				return new BigInteger(string);
			} catch (NumberFormatException e) {
				throw new ValueConverterException("Kein BigInteger", node, e);
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
Re: numeric representation too big for Integer. [message #1300402 is a reply to message #1300376] Thu, 17 April 2014 14:49 Go to previous messageGo to next message
Ed Willink is currently online Ed WillinkFriend
INT is bound to the IntValueConverter that uses Integer.parseInt, but it
is injectable so you might manage to replace it. However you're liable
to find other places whether the special behavior of INT is assumed so
much better to introduce a new terminal.
Ed Willink
On 17/04/2014 15:26, Christophe Bouhier wrote:
> 4294967295
> is 32bit signed, so this won't fit. So I guess I need a unsigned int
> here.
> '-'? ('0'..'9')+;
> Thank You,
> Christophe
Re: numeric representation too big for Integer. [message #1300737 is a reply to message #1300401] Thu, 17 April 2014 19:46 Go to previous message
On 17-04-14 16:49, Christian Dietrich wrote:
> yes you have to
> INT
Thanks!
> @Inject
> @Override
> try {
> node, e);
Previous Topic:Xtext' editor embedded in a Java Application
Next Topic:Literal string conflict
Current Time: Thu Feb 22 15:16:06 GMT 2018
Powered by FUDForum. Page generated in 0.03222 seconds
