Connecting to CDO repository [message #1274544] |
Fri, 21 March 2014 16:10 |
Florian Dunz Messages: 20 Registered: March 2014 |
Junior Member |
Hey,
I've been playing around with Sirius for the last 2 weeks at work. As I've gotten pretty much the hang of it now I'd like to know how to connect to a CDO repository.
I'm able to load the resource in the "Basicfamily" Model Editor though I've yet to find a way for actually creating a representation for it. The editor also seems to not even care when I'm loading the resource, after closing and reopening the editor the just added resource is gone. I've found multiple bits of code where CDO is referenced inside the sirius source which let's me thinking that there should be a way.
I'd greatly appreciate if you could help me on how to connect and create representations for a CDO repo.
Florian
Edit (25.03.2014): Maybe I should clarify my question. How do I create representations for a model which is saved on a CDO repository. Can I save the corresponding .aird files on CDO aswell, what about the .odesign? How do I tell Sirius where those files are located?
[Updated on: Tue, 25 March 2014 07:18] Report message to a moderator
Re: Connecting to CDO repository [message #1277635 is a reply to message #1274544] |
Wed, 26 March 2014 09:03 |
Le 21/03/2014 17:17, Florian Dunz a écrit :
> Hey,
Hi.
This is not supported out-of-the-box by Sirius itself.
The integration between Sirius and CDO comes with Obeo Designer, a
commercial offer provided by Obeo. Based on an annual subscription, it
includes real-time collaborative edition on all types of Sirius
representations.
The current version of Obeo Designer (6.2) is based on a version of
Sirius before it was an Open Source project at Eclipse. But the next
major version of Obeo Designer (7.0) will be based on Sirius. You can
get more information, including an evaluation version (with no feature
restrictions) at http://www.obeodesigner.com/.
Disclaimer: I am an Obeo employee and part of the Obeo Designer team.
These references are only in comments, and maybe some error messages;
they do not make Sirius itself depend on CDO. We will remove them at
some point (with no loss of functionality, just more general code and
messages wording).
Pierre-Charles David
Pierre-Charles David - Obeo
Re: Connecting to CDO repository [message #1277665 is a reply to message #1277635] |
Wed, 26 March 2014 09:43 |
Junior Member |
Thanks for the reply!
I've been playing around a little more and was able to connect to the cdo repo and display the model stored on it.
I've achieved this by modifing the .aird file. Replacing all href="..." which pointed to the locally stored model with something like: href="cdo.net4j.tcp://username:password@localhost:2036/cdo_repo/cdo.library"
After closing and reopening the project which hold the .aird file I can open the diagram. It'll display the cdo.library model stored on cdo.
But quite a lot problems come along with this:
-Sirius changes the href by itself to a canonical one which makes it something like: href="cdo://a4cd80a2-56ed-46c0-b988-8671b80be088/cdo.library" For some reason after restarting eclipse the diagram gets corrupted and the message: "Impossible to find an interpreter - Could not find a session for model element" is displayed along with runtimeexceptions. I'm not sure what to do about this.
- Edit(27.03.2014): Ok, I've understood now why and where the URI is being changed into a canonical one. Is there a way to tell Sirius not to save the canonical one but the URI I acutally gave him in the first place? Where's the input of the .aird file made?
-The diagram doesn't notice updates on the cdo server but the properties view does. A manual view refresh fixes this though I'm not sure where I should implement this to be done automatically.
-Creating a new child on the cdo server causes the whole ide which displays the diagram to crash.
Are there possibilities for me to fix this in an reasonable fashion? Any hint would be appreciated.
Florian
[Updated on: Thu, 27 March 2014 14:01] Report message to a moderator
FUDForum. Page generated in 0.01882 seconds
