java.io.IOException: Cannot allocate memory when running a Java program [message #209175] |
Thu, 07 July 2005 23:50 |
Originally posted by: bandrews.nospam_bphnx.com
Hi All,
After installing Eclipse 3.1 on Linux, I am getting this error A LOT
when I just try to run a Java application from the Run menu. A restart
of Eclipse fixes it. I never had this problem before. Is anyone else
seeing this problem? Here is the stack trace:
java.io.IOException: java.io.IOException: Cannot allocate memory
at java.lang.UNIXProcess.<init>(UNIXProcess.java:148)
at java.lang.ProcessImpl.start(ProcessImpl.java:65)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:451)
at java.lang.Runtime.exec(Runtime.java:591)
at org.eclipse.debug.core.DebugPlugin.exec(DebugPlugin.java:746 )
at org.eclipse.jdt.launching.AbstractVMRunner.exec(AbstractVMRu nner.java:70)
org.eclipse.jdt.internal.launching.StandardVMRunner.run(Stan dardVMRunner.java:241)
org.eclipse.jdt.launching.JavaLaunchDelegate.launch(JavaLaun chDelegate.java:101)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:733)
at org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:931)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
thanks,
B
Re: java.io.IOException: Cannot allocate memory when running a Java program [message #209565 is a reply to message #209175] |
Mon, 11 July 2005 14:34 |
Originally posted by: eclipse3.rizzoweb.com
Barry Andrews wrote:
> Hi All,
Have you tried increasing the VM memory parameters that you use to
launch eclipse (using -vmargs -Xmx256m, etc,)?
HTH,
Eric
Re: java.io.IOException: Cannot allocate memory when running a Java program [message #209588 is a reply to message #209565] |
Mon, 11 July 2005 15:35 |
It's VERY possible that is the problem. When I had 3.1M2, I had a
shortcut on my desktop to start Eclipse with -Xmx300m and -Xms300m, but
when I upgraded to 3.1GA, I did not specify these parameters when I
created the shortcut. Thanks!!! I will try it!
-Barry
>> Hi All,
> HTH,
> Eric
FUDForum. Page generated in 0.03861 seconds
