Home » Eclipse Projects » e(fx)clipse » ClassCastException in PopupMenuService
ClassCastException in PopupMenuService [message #1239496] Tue, 04 February 2014 10:08 Go to next message
Sun Volland is currently offline Sun VollandFriend
When using the PopupMenuService to register a ContextMenu on a TreeCell, I get the following ClassCastException :
org.eclipse.fx.ui.workbench.renderers.fx.DefPopupMenuRenderer$ContextMenuImpl cannot be cast to javafx.scene.control.ContextMenu
at org.eclipse.fx.ui.workbench.renderers.fx.services.PartPopupMenuServiceImpl.registerMenu(PartPopupMenuServiceImpl.java:44)
I guess the problem is due to to the following line (44) in PartPopupMenuServiceImpl.registerMenu() :
return (ContextMenu) menu.getWidget();
which should instead be :
return (ContextMenu)((WPopupMenu<ContextMenu>) menu.getWidget()).getWidget();
Can one confirm this is a bug ?
Sun
Re: ClassCastException in PopupMenuService [message #1239506 is a reply to message #1239496] Tue, 04 February 2014 10:34 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
Yes this looks wrong - unfortunately it is to late for 0.9.0 which has
already been released - if you need this you'll have to get the sources
from git and patch it locally!
Please file a bug so that we can fix it in 1.0.0.
Tom
On 04.02.14 11:08, Sun Volland wrote:
> at
> Sun
Previous Topic:e(fx)clipse nightly are based on Luna
Next Topic:OSGI DS services not working when I am trying start with with different module.
Current Time: Sat Jan 20 03:42:52 GMT 2018
Powered by FUDForum. Page generated in 0.01858 seconds
