Home » Language IDEs » C / C++ IDE (CDT) » Can't get Global Breakpoint to work in Kepler - Hello World
Can't get Global Breakpoint to work in Kepler - Hello World [message #1234328] Tue, 21 January 2014 17:52 Go to next message
Pelle Svensson is currently offline Pelle SvenssonFriend
1. Test application
- CDT / Project Explorer / New / C++ Project
Type: Hello World C++ Project
Tool: Linux GCC
Finnish
- Build
- Debug As / 1. Local C++ Application
- Step until exit
- Terminate and Remove 'Hello Gdb'
2. Global breakpoint
- Put a global breakpoint at HelloGdb.cpp:14 return 0;
- Start debug session.
- Hit F8 run
Program exit no break at global breakpoint!
Using:
Eclipse Version 4.3.1 (Kepler)
CDT:
8.2.1.201310081 org.eclipse.cdt
5.2.0.201310081 org.eclipse.cdt.util
7.2.0.201310081 org.eclipse.cdt.debug.gdbjtag
7.2.1.201310081 org.eclipse.cdt.gdb
GNU gdb (GDB) Fedora 7.6.1-46.fc19
This GDB was configured as "x86_64-redhat-linux-gnu".
Anyone willing to test if this is the case in Kepler?
/Pelle
Re: Can't get Global Breakpoint to work in Kepler - Hello World [message #1234622 is a reply to message #1234328] Wed, 22 January 2014 11:57 Go to previous messageGo to next message
Marc Khouzam is currently offline Marc KhouzamFriend
You can look at the 'gdb traces' to see in more detail what is happening:
http://wiki.eclipse.org/CDT/User/FAQ#I.27ve_been_asked_for_.27gdb_traces.27.2C_where_can_I_find_them.3F
Marc
Re: Can't get Global Breakpoint to work in Kepler - Hello World [message #1234635 is a reply to message #1234622] Wed, 22 January 2014 12:43 Go to previous message
There are no reference to any global breakpoint in the gdb trace.
I did a test with a default Eclipse/CDT build (CDT_8_2_1.zip) and there are no global breakpoints at all in that one. I'm running a Eclipse version distributed with Fedora 19 and they probably added some other plugins.
My actual problem with the breakpoints was that forked processes couldn't be debugged and thereby focus on my first problem 'Global Breakpoints'
Second problem with normal breakpoints resulting in following error after fork:
Error in re-setting breakpoint 3: Warning:
Cannot insert breakpoint 3.
Error accessing memory address 0xc18: Input/output error.
This was due to gcc/g++ options -fPIE -pie -rdynamic
So problem is solved now.
index.php/fa/17308/0/
/Pelle
  • Attachment: Untitled.png
    (Size: 44.02KB, Downloaded 605 times)
Previous Topic:Launch eclipse session without executable
Next Topic:Multiple Src Folders
Current Time: Wed Feb 21 13:31:25 GMT 2018
Powered by FUDForum. Page generated in 0.01646 seconds
