Re: Using Sirius on external files (and without the Model Explorer) [message #1221839 is a reply to message #1221645] |
Wed, 18 December 2013 14:21 |
Hello Patrick,
You can design your RCP application using Sirius as you described. The modeling project nature and the Model Explorer view are default mode/view for Sirius. It is possible to work with aird files and semantic resources in standard projects. You can already try by removing the Modeling project nature on a project sample (right click on the project, Configure/Remove Modeling Project Nature). Sirius is contributing, by extension points, to the Common Navigator Framework some content provider, common sorter and common filter(sirus.ui -> plugin.xml -> extension org.eclipse.ui.navigator.viewer). Therefore, Sirius can be used as well in the Model Explorer view as in the Project Explorer view. If you want to develop your own Tree Viewer, you should probably reuse the common navigator and bind the Sirius extensions to your viewer (and the org.eclipse.ui.navigator.resourceContent which provide the project/foler/file elements).
Steve
Steve Monnier - Obeo Canada
FUDForum. Page generated in 0.02919 seconds
