Home » Modeling » TMF (Xtext) » EMF + Xtext 2.4.3: Error in serialization of EObject
EMF + Xtext 2.4.3: Error in serialization of EObject [message #1219237] Mon, 02 December 2013 20:17 Go to next message
J A is currently offline J AFriend
Member
Dear all,
I have got one working DSL Text Editor, thanks to XText 2.4.3.
Now, when I want to add GUI support to this text editor, so that the user could use SWT/JFace components to edit the model, I have the following error while serializing an EObject back to the text editor resource. This EObject is the root of the modified tree after cloning a node EObject and inserting that clone back to the tree.
// Code that copies one EObject
AnnotatedElement original = new AnnotatedElement();
AnnotatedElement clone = EcoreUtil2.cloneWithProxies(original );
org.eclipse.emf.common.command.Command theCommand = AddCommand.createcreate(org.eclipse.emf.edit.domain.EditingDomain domain, Object original.getOwner(), Object feature, Object clone);
org.eclipse.emf.edit.domain.CommandStack.execute(theCommand);
// Code that serializes the EObject that is the root of the AST Tree
org.eclipse.emf.edit.domain.EditingDomain editingDomain = new EditingDomain();
final XtextDocument doc = (XtextDocument) xtextEditor.getDocument();
doc.modify(new IUnitOfWork.Void<XtextResource>()
	public void process(XtextResource resource) throws Exception
		Injector injector = Guice.createInjector(new ExampleRuntimeModule());
		org.eclipse.xtext.serializer.impl.Serializer serializer = injector.getInstance(org.eclipse.xtext.serializer.impl.Serializer.class);
	        EObject rootEObj = editingDomain.getResourceSet().getResources().get(0).getContents().get(0);
		String serializedDoc = serializer.serialize(eObj);
		doc.set(serializedDoc);
The code above compiles (and what you see is the simplified version) and now for this model:
import BaseMath.*;
import BaseModel.*;
model Example uses BaseModel
	version : "00.00.000.000";
	root
		variable TREEROOT
			variable VARIABLE_1
				datatype : string;
				formula : If(1, 2, 3);
				title : "Var title 1";
The error occurs when I copy VARIABLE_1 in that model
No EObjectDescription could be found in Scope IdentifierExpression.declaration for FinancialModel.elements[0]->AnnotatedElement.element->LibraryDeclaration'BaseMath'.elements[117]->AnnotatedElement.element->FunctionDeclaration'If'
Semantic Object: FinancialModel.elements[0]->AnnotatedElement.element->Model'Example'.root->Root'Root'.elements[0]->AnnotatedElement.element->Variable'TREEROOT'.elements[1]->AnnotatedElement.element->Variable'VARIABLE_1_COPY'.statements[1]->AssignmentStatement.value->ValueList.valueItems[0]->ValueItem.value->IdentifierExpression'If'
[Updated on: Tue, 03 December 2013 10:36]
Report message to a moderator
Re: The grammar, domain specific file [message #1219239 is a reply to message #1219237] Mon, 02 December 2013 20:22 Go to previous messageGo to next message
Member
grammar com.mydomain.ide.example.Example with com.mydomain.ide.expression.Expression
generate example "http://www.mydomain.com/ide/example/Example"
import "http://www.mydomain.com/ide/expression/Expression" as expression
ExampleModel:
	(	expression=Expression |
			imports+=ImportStatement*
			elements+=AnnotatedElement*
ImportStatement:
	'import' importedNamespace=FqnWithWildCard ';'
AnnotatedElement:
	annotations+=Annotation*
	element=AbstractElement
AbstractElement:
	AbstractDeclaration
	| AbstractContainer
	| Model
	| EnumItem
	| Parameter
AbstractContainer:
	AbstractVariable
	| Module
AbstractVariable:
	Root
	| Variable
	| Tuple
AbstractDeclaration:
	BlockDeclaration
	| ParameterTypeDeclaration
	| PropertyTypeDeclaration
	| AnnotationDeclaration
	| ConstantDeclaration
	| PropertyDeclaration
	| FunctionDeclaration
	| LibraryDeclaration
	| ContextDeclaration
AnnotationDeclaration:
	'annotation' name=Fqn ';'
BlockDeclaration:
	'block' name=Fqn ';'
PropertyTypeDeclaration:
	'propertytype' name=Fqn ';'
ParameterTypeDeclaration:
	'parametertype' name=Fqn ';'
PropertyDeclaration:
 	'property' name=Fqn ':' propertyType=[PropertyTypeDeclaration|Fqn] enumList=EnumList? ';'
EnumList:
	'(' items+=EnumItem (',' items+=EnumItem)* ')'
EnumItem:
	name=Fqn
ConstantDeclaration:
	'constant' name=Fqn ':' returnType=[ParameterTypeDeclaration] ';' (external?='external' ';')?
FunctionDeclaration:
	'function' name=Fqn '(' (parameters+=Parameter (';' parameters+=Parameter)*)? ')'
	':' returnType=[ParameterTypeDeclaration] ';' ((external?='external' ';') | body=FunctionBody )
Parameter:
	name=ID  ':' parameterType=[ParameterTypeDeclaration]
FunctionBody:
	'{' expression=Expression '}'
LibraryDeclaration:
	'library' name=Fqn
ContextDeclaration:
	'context' name=Fqn
Model:
	'model' name=Fqn
		'uses' contexts+=[ContextDeclaration|Fqn] (',' contexts+=[ContextDeclaration|Fqn])*
		statements+=AssignmentStatement*
		root=Root
Module:
	'module' name=Fqn
		(elements+=AnnotatedElement
		| propertyGroups+=PropertyGroup
		| elements+=IncludeStatement)*
//If all sub classes implement the same property then Xtext
//expects the property to be in the super class of the sub classes.
//That's the reason why root has an optional element 'name'; to
//enable us to move the name property to AbstractElement.
Root: {Root}
	'root' name=Fqn?
enum SummationOperator:
	ADD='+' | SUBTRACT='-' | RESULT='='
Tuple:
	'tuple' summationOperator=SummationOperator? name=Fqn
Variable:
	'variable' summationOperator=SummationOperator? name=Fqn
		('refers' 'to' refersTo=[AbstractElement|Fqn])?
		propertyGroups+=PropertyGroup*
Annotation:
	'@' declaration=[AnnotationDeclaration|Fqn]
		'(' (arguments+=ValueItem (',' arguments+=ValueItem)*)? ')' ';'
PropertyGroup:
	'group' declaration=[PropertyDeclaration|Fqn]
IncludeStatement:
	'include' module=[Module|Fqn] ';'
AssignmentStatement:
	element=[AbstractElement|Fqn] ':' (value=ValueList  | linked?='grouped') ';'
ValueList:
	valueItems+=ValueItem (',' valueItems+=ValueItem)*
ValueItem:
	value=Expression | value=Validator
enum ValidatorType:
	MINEXCLUSIVE='>' | MININCLUSIVE='>=' | MAXEXCLUSIVE='<' | MAXINCLUSIVE='<='
Validator:
	(type1=ValidatorType number1=UnaryExpression)
	('and' type2=ValidatorType number2=UnaryExpression)?
FqnWithWildCard:
	Fqn ('.*')?
Fqn:
	ID ('.' ID)*
/* Overrides IdentifierExpression from Expression.xtext */
IdentifierExpression:
	hasAmpersand?='&'? declaration=[AbstractElement|Fqn] extension=IdentifierExtension?
[Updated on: Tue, 03 December 2013 07:28]
Re: The grammar, domain generic file [message #1219240 is a reply to message #1219239] Mon, 02 December 2013 20:24 Go to previous message
Member
grammar com.mydomain.ide.expression.Expression with org.eclipse.xtext.common.Terminals
  hidden(WS, ML_COMMENT, SL_COMMENT)
generate expression "http://www.mydomain.com/ide/expression/Expression"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Expression:
	ImpliesExpression
 * Operator precedence from lowest to highest:
 *  implies
 *  or
 *  * | / | mod
 *  and
 *  not | - | +  << unary operators
 *  literals & function calls
enum ImpliesOperator returns BinaryOperator:
	IMPLIES='implies'
ImpliesExpression returns Expression:
	RelationalExpression (
		{BinaryExpression.left = current}
		operator=ImpliesOperator
		right=RelationalExpression
enum RelationalOperator returns BinaryOperator:
	GREATER='>' | SMALLER='<' | GREATEREQUAL='>=' | SMALLEREQUAL='<='
RelationalExpression returns Expression:
	EqualityExpression (
		{BinaryExpression.left=current}
		operator=RelationalOperator
		right=EqualityExpression
enum EqualityOperator returns BinaryOperator:
	EQUAL='=' | NOTEQUAL='<>'
EqualityExpression returns Expression:
	AdditiveExpression (
		operator=EqualityOperator
		right=AdditiveExpression
enum AdditiveOperator returns BinaryOperator:
	PLUS='+' | MINUS='-' | CONCAT='&'
AdditiveExpression returns Expression:
	OrExpression (
		operator=AdditiveOperator
		right=OrExpression
enum OrOperator returns BinaryOperator:
	OR='or'
OrExpression returns Expression:
	MultiplicativeExpression (
		operator=OrOperator
		right=MultiplicativeExpression
enum MultiplicativeOperator returns BinaryOperator:
	MULTIPLY='*' | DIVIDE='/' | MODULO='mod'
MultiplicativeExpression returns Expression:
	AndExpression (
		operator=MultiplicativeOperator
		right=AndExpression
enum AndOperator returns BinaryOperator:
	AND='and'
AndExpression returns Expression:
	PowerExpression (
		operator=AndOperator
		right=PowerExpression
enum PowerOperator returns BinaryOperator:
	POWER='^'
PowerExpression returns Expression:
	UnaryExpression (
		operator=PowerOperator
		right=UnaryExpression
enum UnaryOperator:
	NOT='not' | NEGATIVE='-' | POSITIVE='+'
UnaryExpression returns Expression:
	({UnaryExpression}
		operator=UnaryOperator expression=PrimaryExpression
	| PrimaryExpression
PrimaryExpression returns Expression:
	LiteralExpression
	| ParenthesizedExpression
ParenthesizedExpression returns Expression:
	{ParenthesizedExpression}
	'(' innerExpression=Expression ')'
LiteralExpression returns Expression:
	LiteralNumber
	| LiteralPercentage
	| LiteralString
	| LiteralKeyword
LiteralPercentage:
	value=Double '%'
LiteralNumber:
	value=Double
LiteralString:
	hasAmpersand?='&'? value=STRING
enum KeywordValue:
	X='X'
	| Y='Y'
	| Z='Z'
	| ROOT='ROOT'
LiteralKeyword:
	(keyword=KeywordValue)
//An identifier expression can be a variable, function or a constant.
//It's not possible to define these in separate production rules,
//because the parser can't decide between rules that start with the
//same terminal or production rule; in this case the terminal 'ID',
//because the ampersand is optional.
	hasAmpersand?='&'? name=ID extension=IdentifierExtension?
IdentifierExtension:
	CellSpecifier | ArgumentList
CellSpecifier:
	'[' column=Expression (',' tsy=Expression)?	']'
ArgumentList:
	'(' arguments+=Argument (',' arguments+=Argument)* ')'
Argument:
	itemList=CaseItemList | expression=Expression
CaseItemList:
	'[' items+=CaseItem (( separators+=CaseItemSeparator ) items+=CaseItem)* ']'
enum CaseItemSeparator:
	PIPELINE='|' | COLON=':'
enum CaseItemOperator returns BinaryOperator:
	GREATER='>' | SMALLER='<' | GREATEREQUAL='>=' | SMALLEREQUAL='<=' | EQUAL='=' | NOTEQUAL='<>'
CaseItem:
	operator=CaseItemOperator? expression=Expression
Double returns ecore::EDouble:
	INT+('.'INT)?
//The standard ID terminal rule is overridden here, because of the
//power operator defined in the original ID terminal rule.
terminal ID	: ('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
Previous Topic:newbie: how to generate multiple files from one model element
Next Topic:Is there a memory leak of xtext editors opened by debugger?
Current Time: Sat Jan 20 11:30:22 GMT 2018
Powered by FUDForum. Page generated in 0.01883 seconds
