Home » Eclipse Projects » Web Tools Project (WTP) » assigning DTD to XML doc without specifying it in XML itself
assigning DTD to XML doc without specifying it in XML itself [message #192939] Tue, 22 May 2007 02:00 Go to next message
Eclipse User
Originally posted by: neerajkarandikar.gmail.com
I have various XML documents in my plug-in which use default XML editor.
Each of these documents have a DTD stored somewhere in my workspace. I want
to validate these XMLs using the DTD without specifying them in the XML
docuement it self but my plug-in should take care of finding this DTD
depending upon editor instance and validating XML document against
respective DTD. Is that possible?
Thanks a lot for your help.
Neeraj
Re: assigning DTD to XML doc without specifying it in XML itself [message #193070 is a reply to message #192939] Fri, 25 May 2007 02:26 Go to previous messageGo to next message
Craig Salter is currently offline Craig Salter
Yeah it's possible (at least the way I'm interpretting what you're asking
for).
You can specify an extension in your plugin.xml to map a DTD (that can
live in your plugin) to a particular publicId or systemId 'key'. In the
case of a systemId this is usually an actual or hypothetical web address
(e.g. http://www.example.org/stuff/foo.dtd). Then your XML instance files
just need to include a DOCTYPE that specifies the 'keyed' publicId or
systemId. This way you'll avoid having to put the DTD in your workspace.
We register lots of industry standard XML Schema and DTDs files in WTP
this way.
Take a look at the XML Catalog tutorial [1]. Also take a look at plugin
named
org.eclipse.wst.html.standard.dtds. That should give you a good example
that you can copy/paste for your own needs.
good luck!
craig
[1]
http://www.eclipse.org/webtools/community/tutorials/XMLCatal og/XMLCatalogTutorial.html
neeraj wrote:
> Neeraj
Re: assigning DTD to XML doc without specifying it in XML itself [message #193387 is a reply to message #193070] Tue, 29 May 2007 00:49 Go to previous messageGo to next message
Eclipse User
Hi Craig,
Thanks for your reply.
The problem at my end is we have lots of old XML docs without DOCTYPE
definition present in them. Now, we want these documents to be validated
against a specified DTD from within eclipse runtime without actually
mentioning the DOCTYPE definition in all those documents.
The way we want to do this is to keep a DTD document somewhere accessible
from eclipse env. Then on Read / Save / Modify(show Content
assist) of typical XML documents parse these document against that DTD.
Also we use the eclipse default XML editor for editing these documents.
Is there any way to achieve this?
Neeraj
"craig" <csalter@ca.ibm.com> wrote in message
news:a024f46e8466ed205c3aa39b25b4532a$1@www.eclipse.org...
> for).
> this way.
> named
> good luck!
> craig
> [1]
> neeraj wrote:
>> want to validate these XMLs using the DTD without specifying them in the
>> XML docuement it self but my plug-in should take care of finding this DTD
>> Neeraj
Re: assigning DTD to XML doc without specifying it in XML itself [message #193628 is a reply to message #193387] Wed, 30 May 2007 09:37 Go to previous message
Currently you can only get proper grammar support (validation, content
assist, etc.) for an xml file that specifies a DOCTYPE, xml namespace or
xsi:schemaLocation / xsi:noNamespaceSchemaLocation. Unless you've got one
of those the validator and editor don't know how to find your grammar.
It'd be useful to see a 'sample' of your file to verify that your use case
is a lost cause.
BTW, It's possible that the validator and editor *could* be enhanced to
consider the root element name and use the XML Catalog to look up a
grammar registered for the root element. However, that sounds like a
significant code change and testing effort. Until someone volunteers to
take on such an effort, I'd recommend just modifying your XML files to
provide grammar information (such as a DOCTYPE in the DTD case).
hope that helps!
neeraj wrote:
> Hi Craig,
> Neeraj
>> for).
>> this way.
>> named
>> good luck!
>> craig
>> [1]
>> neeraj wrote:
>>> Hi,
>>> Neeraj
Previous Topic:running apache tomcat 5.5 under eclipse behaves differently than at the command line (on windows)
Next Topic:2nd level dependencies not being included in .war file
Current Time: Sun May 19 08:50:25 EDT 2013
Powered by FUDForum. Page generated in 0.01604 seconds
