Home » Language IDEs » ServerTools (WTP) » applet dependecy
applet dependecy [message #186082] Fri, 12 January 2007 14:07 Go to next message
Originally posted by: exquisitus.nospam.net
hi folks!
how can i setup a dependency between a applet (jar) and a web project,
so every time i export a war, it will contain the packaged jar applet in
WebContent/something?
tnx,
exquisitus, alias xmas_spirit :)
Re: applet dependecy [message #186145 is a reply to message #186082] Fri, 12 January 2007 20:12 Go to previous message
Larry Isaacs is currently offline Larry IsaacsFriend
exquisitus wrote:
> hi folks!
> tnx,
I'm not aware of any dependency support for web content like there is
for Java classes and Java utility projects. You could try adding an Ant
Builder to the applet project that builds a jar file in the web project.
The Ant script could write the jar directly to the WebContent folder
(or subfolder) of the web project. Alternatively it could write the jar
to a different folder (such as AppletContent) in the web project and
manually modify the ".settings/org.eclipse.wst.common.component" file to
include the jar in the desired location of war's web content.
Larry
Previous Topic:turning off tomcat logs
Next Topic:Axis2 Integration
Current Time: Mon Feb 19 16:40:14 GMT 2018
Powered by FUDForum. Page generated in 0.01812 seconds
