Home » Language IDEs » ServerTools (WTP) » Error if opening a xml file from subclipse-history
Error if opening a xml file from subclipse-history [message #181710] Wed, 18 October 2006 12:01
Originally posted by: zkoppany.gmx.de
I use eclipse-3.2.1 with wtp-1.5.2 (with 1.5.1 had the same) on Windows with
java-1.5.0_08.
If I try to open an xml file from subclipse history and got stack trace
below. Any ideas?
Zsolt
org.eclipse.wst.sse.ui.StructuredTextEditor.update(Structure dTextEditor.java:3047)
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.addSourcePage(XMLMultiPageEditorPart.java:338)
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.createPages(XMLMultiPageEditorPart.java:505)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:276)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2595)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2528)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2520)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2505)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2500)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2477)
org.tigris.subversion.subclipse.ui.actions.OpenRemoteFileAct ion$1.run(OpenRemoteFileAction.java:59)
org.tigris.subversion.subclipse.ui.repository.RepositoryMana ger.run(RepositoryManager.java:375)
org.tigris.subversion.subclipse.ui.actions.SVNAction$1.run(S VNAction.java:226)
org.tigris.subversion.subclipse.ui.actions.SVNAction$2.run(S VNAction.java:235)
org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:232)
org.tigris.subversion.subclipse.ui.actions.OpenRemoteFileAct ion.execute(OpenRemoteFileAction.java:36)
org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:56)
org.tigris.subversion.subclipse.ui.history.SVNHistoryPage$24 .run(SVNHistoryPage.java:882)
org.tigris.subversion.subclipse.ui.history.SVNHistoryPage$11 .handleEvent(SVNHistoryPage.java:445)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Previous Topic:WTP 1.5.0 / Eclipse 3.2.0 Deployment problem
Next Topic:Finding the context root and tomcat version of WTP projects programmatically
Current Time: Thu Jan 18 00:21:15 GMT 2018
Powered by FUDForum. Page generated in 0.02218 seconds
