Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Having trouble getting TPTP 3.3 to work with Eclipse 3.0
Having trouble getting TPTP 3.3 to work with Eclipse 3.0 [message #17047] Tue, 26 April 2005 18:27 Go to next message
Eclipse User
Originally posted by: jeffrey.kesselman.sun.com
Hi Guys,
im SURE this is a stupid question and I;m sorry, but I thought I
carefully follwoed the isntructions on the website. I downloaded
the three hyades Zips into m yeclispe directory (runtime, test and
exampels) and verified that they put .so files in the plugins
directory. I downlaoded the rac, unzipepd it to ist own dir, and got it
running.
Then i restarted eclipse.
The problem is I see no eidence of the plug-in in eclispe. i have no
profiling perspective nor do I seme to have a button or menu item to
start the profiler.
What should I be checking?
JK
Re: Having trouble getting TPTP 3.3 to work with Eclipse 3.0 [message #17077 is a reply to message #17047] Tue, 26 April 2005 19:36 Go to previous messageGo to next message
Eclipse User
Additional information. I checked the plug-ins using the About menu. I
see all sorts of Hyades plugins in the list.
But I have no Profilig and Logging perspective that I can find :(
Help? Please?
Re: Having trouble getting TPTP 3.3 to work with Eclipse 3.0 [message #17278 is a reply to message #17077] Mon, 02 May 2005 08:51 Go to previous messageGo to next message
George Christelis is currently offline George Christelis
Hi Jeff,
Only thing I can think of is to try and delete everything in your
eclipse/configuration directory, except for the config.ini file. This might
result in the plugins loading correctly.
George
"Jeff Kesselman" <jeffrey.kesselman@sun.com> wrote in message
news:d4mjgu$5u4$1@news.eclipse.org...
> Help? Please?
Re: Having trouble getting TPTP 3.3 to work with Eclipse 3.0 [message #17305 is a reply to message #17278] Mon, 02 May 2005 12:54 Go to previous message
Alex Nan is currently offline Alex Nan
You also need to download and unzip into your Eclipse directory the EMF
2.0.2 and XSD 2.0.2 packages. This will do the trick.
"George Christelis" <george.christelis@scapatech.com> wrote in message
news:d5583c$jtp$1@news.eclipse.org...
> Hi Jeff,
might
> George
> > Help? Please?
Previous Topic:Is it possible to use the TPTP framework to test J2EE based applications
Next Topic:Can' open ExecutionStatistic view 3.2A
Current Time: Sat May 25 02:06:53 EDT 2013
Powered by FUDForum. Page generated in 0.01816 seconds
