Home » Eclipse Projects » DSDP - Target Management » RSE: Create Remote Project
RSE: Create Remote Project [message #16647] Mon, 10 December 2007 14:54 Go to next message
Originally posted by: tatsudoshi.criion.net
If I right-click a folder on my server in RSE and 'Create Remote
Project', it shows up in my PhP Explorer. If I then try to open a file I
get a java.lang.NullPointerException.
Any suggestions?
I am using JDK6u3 and Eclipse PDT all-in-one 1.0-R20070917
--- Error log ---
org.eclipse.wst.sse.core.internal.FileBufferModelManager.cre ateURIResolver(FileBufferModelManager.java:419)
org.eclipse.wst.sse.core.internal.FileBufferModelManager.get Model(FileBufferModelManager.java:656)
org.eclipse.wst.sse.core.internal.model.ModelManagerImpl._ge tModelFor(ModelManagerImpl.java:393)
org.eclipse.wst.sse.core.internal.model.ModelManagerImpl.get ModelForEdit(ModelManagerImpl.java:1020)
org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:2113)
org.eclipse.php.internal.ui.editor.PHPStructuredEditor.doSet Input(Unknown
Source)
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:2994)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2451)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3012)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3039)
org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2615)
at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( Unknown
Source)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2719)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2547)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
at org.eclipse.php.internal.ui.util.EditorUtility.openInEditor( Unknown
Source)
Source)
at org.eclipse.php.internal.ui.actions.OpenActionUtil.open(Unkn own Source)
at org.eclipse.php.internal.ui.actions.OpenAction.run(Unknown Source)
org.eclipse.php.internal.ui.actions.SelectionDispatchAction. dispatchRun(Unknown
Source)
org.eclipse.php.internal.ui.actions.SelectionDispatchAction. run(Unknown
Source)
org.eclipse.php.internal.ui.explorer.ExplorerActionGroup.han dleOpen(Unknown
Source)
at org.eclipse.php.internal.ui.explorer.ExplorerPart$5.open(Unk nown Source)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 3)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: RSE: Create Remote Project [message #16667 is a reply to message #16647] Mon, 10 December 2007 16:16 Go to previous messageGo to next message
Kevin Doyle is currently offline Kevin DoyleFriend
PDT all-in-one 1.0-R20070917 doesn't include the latest updates to WST
(WST 2.0.1) that are required to support EFS.
You can get the latest updates for WST by going to Help -> Software
Updates -> Find and Install, then selecting "Search for updates of the
currently installed features.". WST is under The Eclipse Web Tools
Platform (WTP) Project update site.
Also due to bug #181460 (
https://bugs.eclipse.org/bugs/show_bug.cgi?id=181460 ) I would recommend
creating a local php project and then linking folders/files. This way
the project won't be closed on workbench restart. You can link a folder
by creating a new folder, but in the new folder dialog selecting
Advanced, Link to folder in the file system, selecting the file system
to be RSE, and choosing the folder you desire to link. You can do the
same thing in the New File dialog, but you can't do it in the New PHP
File dialog.
Kevin Doyle
> Any suggestions?
> --- Error log ---
> at
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.php.internal.ui.util.EditorUtility.openInEditor( Unknown Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: RSE: Create Remote Project [message #16699 is a reply to message #16667] Tue, 11 December 2007 12:04 Go to previous message
Ah thank you very much :-)
Re: RSE: Create Remote Project [message #571129 is a reply to message #16647] Mon, 10 December 2007 16:16 Go to previous message
File dialog.
Kevin Doyle
> Any suggestions?
> --- Error log ---
> at
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: RSE: Create Remote Project [message #571258 is a reply to message #16667] Tue, 11 December 2007 12:04 Go to previous message
Previous Topic:Connecting to system i via ftp
Next Topic:Many Save Conflicts
Current Time: Thu Apr 26 17:17:51 GMT 2018
Powered by FUDForum. Page generated in 0.02545 seconds
