| Re: unmarshalling issue (different java versions) [message #1124446 is a reply to message #1123425] |
Thu, 03 October 2013 10:44  |
Judith Gull Messages: 33 Registered: February 2010 |
Member |
I have not heard of this problem yet. You can influence serialization/deserialization in the service tunnel with an IObjectReplacer. (see org.eclipse.scout.rt.shared.servicetunnel.ServiceTunnelObjectReplacer). Then you can create your own ServiceTunnelContentHandler instead of DefaultServiceTunnelContentHandler and overwrite createObjectSerializer with your new replacer.
In the client you set the content handler when the session is loaded
public void execLoadSession() throws ProcessingException {
HttpServiceTunnel tunnel = new HttpServiceTunnel(this, getBundle().getBundleContext().getProperty("server.url"));
tunnel.setContentHandler(new MyServiceTunnelContentHandler());
setServiceTunnel(tunnel);
and in the server you can set your own ServiceTunnelServlet with that content handler and register it in the plugin.xml.
I hope this helps. Please give us feedback, if you can solve this problem or ask again, if you need more help! Thanks.
FUDForum. Page generated in 0.01399 seconds
