Home » Modeling » Epsilon » TemplateFactory.load help
TemplateFactory.load help [message #16125] Tue, 21 April 2009 10:56 Go to next message
No real name is currently offline No real nameFriend
Member
Hi there,
I have in an EGL script the following line:
var t : Template := TemplateFactory.load('./Other.egl');
Previously, this line worked, but after my version of Epsilon from the SVN
I find that I get the following error:
Internal error: java.lang.IllegalArgumentException: URI is not absolute
at java.net.URI.toURL[URI.java:1080]
at org.eclipse.epsilon.egl.EglModule.parse[EglModule.java:97]
at org.eclipse.epsilon.egl.types.EglTemplate.<init>[EglTemplate.java:48]
org.eclipse.epsilon.egl.types.EglFileGeneratingTemplate.<init >[EglFileGeneratingTemplate.java:50]
org.eclipse.epsilon.egl.template.FileGeneratingTemplateFacto ry.load[FileGeneratingTemplateFactory.java:51]
at sun.reflect.NativeMethodAccessorImpl.invoke0[Native Method]
Do you have any ideas why this might have occurred.
I believe I am probably using the method incorrectly, as I may have
unintentionally changed some of my code along the lines. However, when
having a naive look in to the code, as to why this might error might be
happenning I noticed that in:
org.eclipse.epsilon.egl.template.TemplateFactory
the resolveTemplate method calls UriUtil.resolve(path, templateRoot, root)
-- and on inspection templateRoot and root are null. Should this be the
case? Perhaps I need to call the TemplateFactory.load method differently?!
Any help to resolve this issue would be much appreciated.
PS. I'm running this EGL script from a standard launch configuration.
All the best,
Edd
Re: TemplateFactory.load help [message #16139 is a reply to message #16125] Tue, 21 April 2009 10:59 Go to previous messageGo to next message
Member
Whoops! Noticed I missed the crucial word of a sentence in my previous
message, sorry!! The sentence should read
Previously, this line worked, but after **updating** my version of Epsilon
from the SVN I find that I get the following error:
Re: TemplateFactory.load help [message #16153 is a reply to message #16139] Tue, 21 April 2009 11:09 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Edd,
This appears to be yet another path-related regression. Could you please
open a bug for it and we'll look into it asap.
Dimitris
> Epsilon from the SVN I find that I get the following error:
Re: TemplateFactory.load help [message #16194 is a reply to message #16153] Wed, 22 April 2009 10:21 Go to previous messageGo to next message
Louis Rose is currently offline Louis RoseFriend
Hi Edd,
Thanks for the message. This is a regression introduced in a recent
change to EGL. I'm about to commit a change to SVN that should fix the
problem. Do let me know if you have any further problems.
I'm investigating why our tests didn't fail. I've opened a bug to track
this, and any further issues:
https://bugs.eclipse.org/273222
Louis.
Dimitris Kolovos wrote:
> Hi Edd,
> Cheers,
> Dimitris
Re: TemplateFactory.load help [message #16223 is a reply to message #16194] Wed, 22 April 2009 11:03 Go to previous messageGo to next message
Member
Hi Louis,
Thanks for the prompt reply and update -- this has fixed the problem...
thanks, that's great!
> ... I've opened a bug to track
Thanks for opening the bug report for me -- I wasn't available for some of
yesterday and this morning I had the nice surprise that you'd resolved the
problem!
> Cheers,
> Louis.
Many thanks,
Edd
Re: TemplateFactory.load help [message #16238 is a reply to message #16223] Wed, 22 April 2009 11:35 Go to previous message
> Hi Louis,
Hi Edd,
You're welcome. Thanks for the report - sorry about the regression!
Louis.
Re: TemplateFactory.load help [message #566895 is a reply to message #16125] Tue, 21 April 2009 10:59 Go to previous message
Member
Re: TemplateFactory.load help [message #566905 is a reply to message #16139] Tue, 21 April 2009 11:09 Go to previous message
Hi Edd,
Dimitris
Re: TemplateFactory.load help [message #566991 is a reply to message #16153] Wed, 22 April 2009 10:21 Go to previous message
Hi Edd,
Louis.
> Hi Edd,
> Cheers,
> Dimitris
Re: TemplateFactory.load help [message #567029 is a reply to message #16194] Wed, 22 April 2009 11:03 Go to previous message
Member
Hi Louis,
problem!
> Cheers,
> Louis.
Many thanks,
Edd
Re: TemplateFactory.load help [message #567048 is a reply to message #16223] Wed, 22 April 2009 11:35 Go to previous message
> Hi Louis,
Hi Edd,
Louis.
Previous Topic:Access to the Diagram Model
Next Topic:EWL setting a profile/stereotype and trigger the wizard
Current Time: Thu Jun 21 14:37:34 GMT 2018
Powered by FUDForum. Page generated in 0.02210 seconds
