| Applications in Simulation Mode [message #1101585] |
Wed, 04 September 2013 13:02  |
Tim Summers Messages: 3 Registered: September 2013 |
Junior Member |
I have an application (plain java) that generates data which is then used to decide which transition is used after a gateway.
When running a simulation I see that the application is not called, but the gateway's simulation setting is used. That behavior seems totally logical but I wonder if there's any way to have the gateway logic been implemented by Java code during a simulation run.
FUDForum. Page generated in 0.01525 seconds
