Re: How to specify Composite background image in CSS. [message #1094342 is a reply to message #1094333] |
Sun, 25 August 2013 14:41 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Erwin,
first your background-image definition should be applied to Composite
CSS element like:
Composite.backgroundimage{
background-image: url( images/my-image.jpg );
Second - try to remove the "-" from the image name.
HTH,
Ivan
On 8/25/2013 5:22 PM, Erwin Hogeweg wrote:
> I am trying to move the definition of a Composite background image
> from code to CSS. In order to do so I created the CSS definition below...
> backgroundimage{
> .. and changed the code as follows:
> Composite theImage = null;
> Image bodyImage = null;
> try {
> theImage = new Composite(wrapper, SWT.NONE);
> // TODO: Need to read image from css. This doesn't work
> (yet)...
> theImage.setData(RWT.CUSTOM_VARIANT, "backgroundimage");
> // bodyImage = new Image(Display.getCurrent(),
> getClass().getClassLoader().getResourceAsStream("images/my-image.jpg"));
> } catch (SWTException swte) {
> // for WindowBuilder test.
> bodyImage = new Image(stack.getDisplay(), 709, 475);
> When I run the app though I see the following error message appear:
> org.w3c.css.sac.CSSException: Failed to read property
> background-image: Failed to read image: images/my-image.jpg
> So there is clearly something wrong with the definition of the image
> location. I followed the instructions from this site:
> http://help.eclipse.org/indigo/index.jsp?topic=/org.eclipse.rap.help/help/html/advanced/theming.html
> and verified that the image is in the specified location.
> This made me think that it is probably the jetty bundle that can't
> find the image, and that I would need a fragment. But after creating
> the fragment I get the exact same result.
> 4 ACTIVE org.eclipse.equinox.http.jetty_3.0.100.v20130327-1442
> Fragments=76
> stop 4
> osgi> start 4
> I also tried to register the image as a resource and than use
> swt-resources/my-image.jpg. Same difference.
> So now I am officially lost!
> Any suggestions are highly appreciated.
> Kind Regards,
> Erwin
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.02876 seconds
