I want to compile a small example from the command line. When I use Eclipse, it works fine. But if I compile the same example from the command line, I get an error.
This is how I compile the example:
java -jar otre/ecotj-R-2.2.0-201306071800.jar -cp otre/org.eclipse.objectteams.runtime_2.2.0.201305210612.jar Example.java
The error message is:
The example works fine in eclipse! Why do I get the error?
I use the same java version in eclipse and from the command line:
java -version
java version 1.7.0_40
OpenJDK Runtime Environment (IcedTea 2.4.1) (ArchLinux build 7.u40_2.4.1-1-x86_64)
OpenJDK 64-Bit Server VM (build 24.0-b50, mixed mode)
thank you for any suggestions!
Stephan
