Home » Modeling » Epsilon » ant build
ant build [message #14727] Wed, 01 April 2009 09:42 Go to next message
Anne is currently offline AnneFriend
Member
I just got the newest Eclipse Ganymede Modeling Package and installed
Epsilon via the update manager with it. Now my ant build files don't seem
to work anymore. I get an elaborate error starting with
"loadModels:
[epsilon.loadModel] Internal error:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Resource
'../Models/sca_v1_ClassDiagram.uml' does not exist."
for the first model it is supposed to load.
I never encountered this error with the previous versions. Did I maybe
forget to configure/think of something?
Thanks in advance for the help,
Anne
Re: ant build [message #14760 is a reply to message #14727] Wed, 01 April 2009 10:33 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Anne,
If you are using relative paths, you should use the file attribute
instead of the value one. For example
<parameter name="modelFile" *file*="../Models/some.uml"/>
will work while
<parameter name="modelFile" *value*="../Models/some.uml"/>
will not.
Dimitris
Anne Keller wrote:
> seem to work anymore. I get an elaborate error starting with
> "loadModels:
> Anne
Re: ant build [message #14789 is a reply to message #14760] Wed, 01 April 2009 11:39 Go to previous messageGo to next message
Member
Hi Dimitri,
I changed
<parameter name="modelFile" value="${basedir}/CardInsert.uml"/>
to
<parameter name="modelFile" file="${basedir}/CardInsert.uml"/>
but that doesn't change the error I get.
Something else I might be overlooking?
Thanks again and regards,
Anne
Re: ant build [message #14817 is a reply to message #14789] Wed, 01 April 2009 11:45 Go to previous messageGo to next message
Hi Anne,
Could you please zip and send me your project so that I can have a look?
Dimitris
Anne Keller wrote:
> Hi Dimitri,
> I changed
> to
> Anne
Re: ant build [message #14847 is a reply to message #14817] Wed, 01 April 2009 13:13 Go to previous messageGo to next message
Hi Anne,
Are you by any chance running Linux? If so, you may need to add a file:/
before your path to make sure that the load model task knows that it's
an absolute path. e.g.
<parameter name="modelFile" value="file:/${basedir}/CardInsert.uml"/>
Dimitris
Dimitris Kolovos wrote:
> Hi Anne,
> Cheers,
> Dimitris
> Anne Keller wrote:
>> Hi Dimitri,
>> I changed
>> to
>> Anne
Re: ant build [message #14874 is a reply to message #14847] Wed, 01 April 2009 13:37 Go to previous messageGo to next message
Member
Solved. :)
There was a misunderstanding. My line read:
<parameter name="modelFile" file="../Models/some.uml"/>
which didn't work. But
works good (On Mac with and without the / ).
Anne
Re: ant build [message #14902 is a reply to message #14874] Wed, 01 April 2009 13:40 Go to previous messageGo to next message
Hi Anne,
Glad this helped :)
The problem is that in Windows you can easily tell if a path is relative
or not e.g. c:/file.txt is definitely absolute while /foo/file.txt is
relative. In Unix-based systems however the latter can be both (thus the
need for the file:/ prefix).
Dimitris
Anne Keller wrote:
> Solved. :)
> Anne
Re: ant build [message #14922 is a reply to message #14902] Wed, 01 April 2009 13:48 Go to previous messageGo to next message
Steffen Zschaler is currently offline Steffen ZschalerFriend
Hi Dimitris,
Actually /foo/file.txt will always be an absolute path on a Unix-based
system. If you want a relative path you need to use foo/file.txt. I
think, Eclipse's standard path handling functions actually use this to
determine if a path is absolute or not, which is why I have found under
Windows you will sometimes have to use paths like /C:/... to make it
very clear to Eclipse that this is indeed an absolute path. Maybe at
some point someone will go in and make sure there is a platform-neutral,
consistently implemented way of identifying absolute vs. relative paths
in Java, but at this point everybody seems to be cooking their own.
Steffen
> Hi Anne,
> Glad this helped :)
> relative or not e.g. c:/file.txt is definitely absolute while
> /foo/file.txt is relative. In Unix-based systems however the latter
> can be both (thus the need for the file:/ prefix).
> Cheers,
> Dimitris
> Anne Keller wrote:
>> Solved. :)
>> Thanks,
>> Anne
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to MDPLE, the 1st International Workshop on
Model-Driven Product Line Engineering
http://www.feasiple.de/workshop_en.html
Re: ant build [message #14938 is a reply to message #14922] Thu, 02 April 2009 12:44 Go to previous message
Hi Steffen,
I agree with everything you said :) I'll put this in my todo list for
further investigation.
Dimitris
Steffen Zschaler wrote:
> Hi Dimitris,
> Cheers,
> Steffen
>> Hi Anne,
>> Glad this helped :)
>> Cheers,
>> Dimitris
>> Anne Keller wrote:
>>> Solved. :)
>>> Thanks,
>>> Anne
Re: ant build [message #566306 is a reply to message #14727] Wed, 01 April 2009 10:33 Go to previous message
Hi Anne,
will work while
will not.
Dimitris
Anne Keller wrote:
> "loadModels:
> Anne
Re: ant build [message #566331 is a reply to message #14760] Wed, 01 April 2009 11:39 Go to previous message
Member
Hi Dimitri,
I changed
to
Anne
Re: ant build [message #566354 is a reply to message #14789] Wed, 01 April 2009 11:45 Go to previous message
Hi Anne,
Dimitris
Anne Keller wrote:
> Hi Dimitri,
> I changed
> to
> Anne
Re: ant build [message #566366 is a reply to message #14817] Wed, 01 April 2009 13:13 Go to previous message
Hi Anne,
Dimitris
> Hi Anne,
> Cheers,
> Dimitris
> Anne Keller wrote:
>> Hi Dimitri,
>> I changed
>> to
>> Anne
Re: ant build [message #566383 is a reply to message #14847] Wed, 01 April 2009 13:37 Go to previous message
Member
Solved. :)
Anne
Re: ant build [message #566399 is a reply to message #14874] Wed, 01 April 2009 13:40 Go to previous message
Hi Anne,
Glad this helped :)
Dimitris
Anne Keller wrote:
> Solved. :)
> Anne
Re: ant build [message #566407 is a reply to message #14902] Wed, 01 April 2009 13:48 Go to previous message
Hi Dimitris,
Steffen
> Hi Anne,
> Glad this helped :)
> Cheers,
> Dimitris
> Anne Keller wrote:
>> Solved. :)
>> Thanks,
>> Anne
Re: ant build [message #566428 is a reply to message #14922] Thu, 02 April 2009 12:44 Go to previous message
Hi Steffen,
Dimitris
> Hi Dimitris,
> Cheers,
> Steffen
>> Hi Anne,
>> Glad this helped :)
>> Cheers,
>> Dimitris
>> Anne Keller wrote:
>>> Solved. :)
>>> Thanks,
>>> Anne
Previous Topic:ant build
Next Topic:Problems View not Showing Markers from EVL
Current Time: Thu Apr 26 09:51:35 GMT 2018
Powered by FUDForum. Page generated in 0.02724 seconds
