Home » Eclipse Projects » Eclipse Platform » Mapping from editorContribution to menuContribution(Can not merge it to one menu.)
Mapping from editorContribution to menuContribution [message #1053504] Mon, 06 May 2013 10:36
Leonid Ripeynih is currently offline Leonid RipeynihFriend
Hi all!
I have a following problem. I have an EditorActionBarContributor, which makes a contribution to the Menu with the following code:
public void contributeToMenu(IMenuManager menuManager) {
  super.contributeToMenu(menuManager);
  IMenuManager submenuManager = new MenuManager(ModelEditorPlugin.INSTANCE.getString("_UI_Example_Menu_Label"), "[b]example.menu.id[/b]");
  menuManager.insertAfter("additions", submenuManager);
  submenuManager.add(new Separator("settings"));
  submenuManager.add(new Separator("actions"));
  submenuManager.add(new Separator("[b]additions[/b]"));
  submenuManager.add(new Separator("additions-end"));
  // Actually fill submenuManager with actions...
In another plugin I have some more functionality, I'd like to contribute to editor, so I've created an editorContribution to add more actions. They're defined with the following plugin.xml code:
<extension point="org.eclipse.ui.editorActions">
  <editorContribution
    id="example.editor.contrib"
    targetID="example.editorId">
    <action
      id="example.editor.contrib.a1"
      label="%_UI_A1_Label"
      menubarPath="[b]example.menu.id[/b]/[b]additions[/b]"
      class="example.actions.contrib.Action1"/>
  </editorContribution>
</extension>
It works fine, and new action is contributed in exactly the same menu, created by EditorActionBarContributor.
But, as far as I know, a modern way to add actions is via Command Framrwork. I have some Handlers in project (in it's CNF part), so I decided to move that contributions to Command Framework as well. I've read this http://wiki.eclipse.org/Menus_Extension_Mapping, but I don't understand how exactly map an editorContribution to menuContribution? My current attempts are:
First (Creates a separarate entry in main menu)
<extension point="org.eclipse.ui.menus">
  <menuContribution
    locationURI="menu:org.eclipse.ui.main.menu?after=additions">
    <command
      commandId="example.commands.c1"
      label="%_UI_Command1_Label"
      style="push">
      <visibleWhen checkEnabled="false">
        <with variable="activePartId">
          <equals value="example.editorId"/>
        </with>
      </visibleWhen>
    </command>
  </menuContribution>
</extension>
Second (Nothing is visible)
  <menuContribution
    locationURI="menu:org.eclipse.ui.main.menu?after=[b]example.menu.id[/b]">
    <command
      style="push">
        </with>
      </visibleWhen>
    </command>
  </menuContribution>
</extension>
Third(duplicates menu, inserts command in that menu)
  <menuContribution
    <menu
      id="[b]example.menu.id[/b]"
      label="%_UI_Example_Menu_Label">
        </with>
      </visibleWhen>
      <command
        style="push">
          </with>
        </visibleWhen>
      </command>
    </menu>
  </menuContribution>
</extension>
Non of which is working in same way like editorContribution. Am I doing something wrong, or is it a limitation of the Platform? Is there any workaround or way to fix it?
Previous Topic:actions form contextmenu executed twice
Next Topic:RCP app with Worldwind - Globe vanishes
Current Time: Fri May 25 22:57:36 GMT 2018
Powered by FUDForum. Page generated in 0.01982 seconds
