Home » Modeling » TMF (Xtext) » Self-triggered Autocomplete
Self-triggered Autocomplete [message #1053469] Mon, 06 May 2013 07:38 Go to next message
junior developer is currently offline junior developerFriend
Hi all,
When I write program, i want to auto generate a guid for every meta class instance automatically.
Example:I wanted
Filesystem default { quid ="sss33432"
Drive D { guid ="2243rdffgf"
File filename guid="dfdf5" ;}
quid ="sss33432" is generated automatically. Hence, i want to user dont write guid,it is generated automatically from program when user write ' Filesystem default{ ' then it must triggered from program and program must write generated guID (from java class).
is it possibble ? If possible how can i implement this feature to my DSL ?
Re: Self-triggered Autocomplete [message #1053478 is a reply to message #1053469] Mon, 06 May 2013 08:28 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
digg into DefaultAutoEditStrategyProvider
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Self-triggered Autocomplete [message #1053546 is a reply to message #1053478] Mon, 06 May 2013 13:12 Go to previous messageGo to next message
Hi Christian,
thank you for help .
Re: Self-triggered Autocomplete [message #1053557 is a reply to message #1053478] Mon, 06 May 2013 14:07 Go to previous messageGo to next message
Hi Christian ,
I used DefaultAutoEditStrategyProvider and i have been solve my problem. But When i add
string to end of program my offset of cursor not localate to end of string. So i want
to ask u How can i change my cursor location ?
Re: Self-triggered Autocomplete [message #1053561 is a reply to message #1053557] Mon, 06 May 2013 14:24 Go to previous messageGo to next message
Sorry no idea
Re: Self-triggered Autocomplete [message #1053572 is a reply to message #1053561] Mon, 06 May 2013 14:56 Go to previous messageGo to next message
Hi Christian
Thank you
Re: Self-triggered Autocomplete [message #1053588 is a reply to message #1053561] Mon, 06 May 2013 15:54 Go to previous message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Am 06.05.13 16:24, schrieb Christian Dietrich:
> Sorry no idea
You may want to implement ISourceViewerAware which allows you to access
the source viewer in your auto edit strategy. This will in turn provide
means to set the selection, e.g. the cursor position.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Previous Topic:ambiguity in the grammar
Next Topic:Weird Scope provider behavior
Current Time: Thu May 24 02:36:55 GMT 2018
Powered by FUDForum. Page generated in 0.02374 seconds
