Home » Eclipse Projects » Remote Application Platform (RAP) » chart tools for RAP
chart tools for RAP [message #1044259] Thu, 18 April 2013 17:25 Go to next message
Julia Kurde is currently offline Julia KurdeFriend
Member
I'm looking for a nice tool or widged that can generate and display charts. If possible with tooltips at data points and dynamic, so the user can resize or zoom it.
In RCP applications we embed the AWT libary jFreeChart (www.jfree.org), which provides great functionality but unfortunately does not work in RAP.
The google widges from the RAP incubator page look promissing, but their demo does not run under RAP 2.0 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=405552).
Does the RAP community have any advices for me about what chart tools I could use?
Thanks!
Re: chart tools for RAP [message #1044366 is a reply to message #1044259] Thu, 18 April 2013 20:42 Go to previous messageGo to next message
Cole Markham is currently offline Cole MarkhamFriend
I have worked with several chart libraries (including the Google widgets in the incubator). The best solution I have found is to use a Browser widget to display html output from a chart library. That could either be a JavaScript library (e.g., d3js), or a Java library (e.g., jFreeChart, I have used ChartDirector[1], or BIRT[2]). ChartDirector uses HTML image maps and/or JavaScript to add interactivity. See this stackoverlow question on using jFreeChart in a web application[3]. You could use a ServiceHandler or custom Servlet to send the chart image. One advantage of using a Browser-based solution is that if designed properly it will work in RCP as well. When I get some time, I'll try to write a short tutorial.
[1] http://www.advsofteng.com/
[2] http://wiki.eclipse.org/RAP/FAQ#How_to_integrate_BIRT.3F
[3] http://stackoverflow.com/questions/1975208/how-can-i-display-a-jfreechart-in-web-browser-with-stripes-framework
Hope that helps,
Cole Markham
Re: chart tools for RAP [message #1046498 is a reply to message #1044366] Mon, 22 April 2013 02:00 Go to previous messageGo to next message
ocean xue is currently offline ocean xueFriend
about application chartDirector, tutorial?
Re: chart tools for RAP [message #1086581 is a reply to message #1046498] Wed, 14 August 2013 11:39 Go to previous messageGo to next message
Johns Robert is currently offline Johns RobertFriend
There is a massive entry in market in terms of graphical representation which is in addition to 3D charting with support of html5 chart [URL removed].
[Updated on: Thu, 05 December 2013 18:18] by Moderator
Report message to a moderator
Re: chart tools for RAP [message #1088161 is a reply to message #1044259] Fri, 16 August 2013 17:26 Go to previous messageGo to next message
Milko Krastev is currently offline Milko KrastevFriend
I bumped into the same problem just two months ago. JFreeChart is great, but the only way to make it work is on the server. That means you generate some snapshot image and send it the client. Which generates lot of traffic even if you want the most basic form of interactivity. Besides, it consumes too much server resources.
The way to go is to embed a Javascript charting library into a Browser widget. There are literary tens of such libraries. Two more notable examples are Highcharts and AMCharts.
Re: chart tools for RAP [message #1089795 is a reply to message #1088161] Mon, 19 August 2013 08:55 Go to previous message
Tim Buschtoens is currently offline Tim BuschtoensFriend
Hi.
My colleague started a simple charting widget based on d3 for RAP:
https://github.com/ralfstx/rap-d3charts
Greetings,
Tim
Am 16.08.2013 19:26, schrieb Milko Krastev:
Tim Buschtöns
Twitter: @EclipseRAP
Previous Topic:SWT.ICON_SEARCH and SWT.ICON_CANCEL not work in the dialog
Next Topic:Different errors occurs in firefox and chrome when I close my custom widget
Current Time: Mon Apr 23 02:18:32 GMT 2018
Powered by FUDForum. Page generated in 0.02279 seconds
