Home » Eclipse Projects » DSDP - Target Management » terminal view in an RCP application
Re: terminal view in an RCP application [message #17611 is a reply to message #15151] |
Wed, 02 January 2008 10:53 |
Originally posted by: enrico.piccinni.gmail.com
Hy,
I'm new to eclipse RCP devloping. I'm trying to develop a RCP
application for monitoring robotics applications as my Ph.D thesis.
I need a terminal in my application and I'd like to use tm-terminal
activated from an action (tool-bar or menu). So far I did:
..) successfully: installed tm-terminal plugin in workbench
..) unseccesfully: try to activate it in my menu application.
Can you help me (i.e code fragmente, tutorial, ecc...) in
>> and drop the plugins you want into your application.
I think I have included all the plugins necessary to display that view
but I got a lot of errors.
Thank you a lot in advance.
enrico
Errors I got:
org.eclipse.tm.internal.terminal.view.TerminalView.setupMenu s(TerminalView.java:541)
org.eclipse.tm.internal.terminal.view.TerminalView.createPar tControl(TerminalView.java:434)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:370)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:227)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:2077)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:1018)
at org.eclipse.ui.internal.WorkbenchPage.access$18(WorkbenchPag e.java:999)
at org.eclipse.ui.internal.WorkbenchPage$19.run(WorkbenchPage.j ava:3666)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
Martin Oberhuber ha scritto:
> Can you be more specific?
> Because the simple answer is,
> download the TM-terminal-2.0.0.1.zip from
> http://download.eclipse.org/dsdp/tm/downloads/
> Or what is it that you'd want beyond that?
> Programmatically creating a connection?
> Search bugzilla for that one.
> Martin Oberhuber
> Target Management Project Lead, DSDP PMC Member
> http://www.eclipse.org/dsdp/tm
> Saeid Zoonematkermani wrote:
>> Hello all,
>> I was wondering whether there is a tutorial, an example or any
>> specific documentation on how to add the "terminal view" to an RCP
>> application.
>> Thank you,
>> - Saeid
Re: terminal view in an RCP application [message #17716 is a reply to message #17611] |
Thu, 10 January 2008 12:57 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hello Enrico,
First of all, what version of the Terminal are you trying? What version
of Eclipse? That's important to know in order to understand the traceback.
When you installed the Terminal into your workbench successfully, you
should be able to use the "Window > Show View > Other > Terminal" menu
to activate it.
Cheers
Martin
Enrico Piccinini wrote:
> Hy,
> enrico
> Errors I got:
> java.lang.NullPointerException
> at
> at
> at
> at
> at
>> Thanks,
>> Martin Oberhuber
>>> Hello all,
>>> application.
>>> Thank you,
>>> - Saeid
Re: terminal view in an RCP application [message #571686 is a reply to message #15151] |
Hy,
enrico
Errors I got:
> Martin Oberhuber
>> Hello all,
>> application.
>> Thank you,
>> - Saeid
Re: terminal view in an RCP application [message #571934 is a reply to message #17611] |
Hello Enrico,
to activate it.
Cheers
Martin
> Hy,
> enrico
> Errors I got:
> at
> at
> at
> at
> at
>> Thanks,
>> Martin Oberhuber
>>> Hello all,
>>> application.
>>> Thank you,
>>> - Saeid
Current Time: Tue Apr 23 12:58:41 GMT 2024
Powered by FUDForum. Page generated in 0.03786 seconds
