Home » Archived » Voicetools » java in voicexml
Re: java in voicexml [message #574798 is a reply to message #14127] Thu, 01 June 2006 00:21 Go to previous messageGo to next message
Mike Greenawalt is currently offline Mike GreenawaltFriend
Member
Sorry, no. VoiceXML scripting and scope and variable semantics is firmly
specified on ECMAScript. See the VoiceXML specification
(http://www.w3.org/TR/voicexml20/#dml5).
You can use the <data> tag or some other construct to interact with a
Java-implemented external application that can deliver results to the
VoiceXML application. But you cannot embed Java code inside the VoiceXML.
-- Mike Greenawalt
"loiy Ababneh" <la1@informatik.uni-ulm.de> wrote in message
news:3fd3e6ed438f8e68150a14751f62f38c$1@www.eclipse.org...
> Hallo very one ,
> i want to use java in VoiceXML tool can i do that , for example
> ?xml version="1.0" encoding="ISO-8859-1"?>
> <vxml version="2.0" xmlns="http://www.w3.org/2001/vxml">
> <var name="hi" expr="'Hello World!'"/>
> <form id="say_hi">
> <block>
> <prompt><value expr="hi"/></prompt>
> <goto next="#say_goodbye"/>
> </block>
> </form>
> <form id="say_goodbye">
> <block>
> Goodbye!
> </block>
> somthing in java to have values from database
> </form>
> </vxml>
> if one can do that Pl. one examlpe
> loiy
Re: java in voicexml [message #574938 is a reply to message #14163] Tue, 20 June 2006 20:46 Go to previous messageGo to next message
Originally posted by: paul.rubenstein.glenayre.com
Hi Loiy,
What you are probably looking for is something like a JSP. You will need
a webserver (such as tomcat) to execute the JSP. You can then produce
something like:
<?xml version="1.0" encoding="ISO-8859-1"?>
<form id="say_hi">
<block>
</block>
</form>
<block>
<prompt>
// JAVA Scriptlet
System.out.println("Goodbye!");
</prompt>
</block>
</form>
</vxml>
> -- Mike Greenawalt
Re: java in voicexml [message #576111 is a reply to message #14216] Wed, 07 February 2007 14:36 Go to previous messageGo to next message
Originally posted by: avtpuser.gmail.com
Hi Paul,
Is there a mechanism to achieve something similar to your response (JSP),
using VTP-GUI?
I am using the VTP Preview build.
"paul rubenstein" <paul.rubenstein@glenayre.com> wrote in message
news:pan.2006.06.20.20.46.03.865345@glenayre.com...
> Hi Loiy,
> something like:
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> <prompt>
> // JAVA Scriptlet
> </prompt>
> </block>
> </form>
> </vxml>
>> -- Mike Greenawalt
Re: java in voicexml [message #634515 is a reply to message #574798] Fri, 22 October 2010 04:15 Go to previous message
loiy is currently offline loiyFriend
Junior Member
Mike Greenawalt wrote on Wed, 31 May 2006 20:21
-- Mike Greenawalt
> Hallo very one ,
> <form id="say_hi">
> <block>
> </block>
> </form>
> <block>
> Goodbye!
> </block>
> </form>
> </vxml>
Previous Topic:Cannot run the "Getting Started" example
Next Topic:java
Current Time: Thu Jun 21 08:54:26 GMT 2018
Powered by FUDForum. Page generated in 0.01890 seconds
