Home » Newcomers » Newcomers » Unable to start Tomcat(Oracle Enterprise Linux 5.5 + Eclipse Juno SR2 + Tomcat 7.0.12)
Unable to start Tomcat [message #1023998] Mon, 25 March 2013 16:02 Go to next message
Simone Sarzano is currently offline Simone SarzanoFriend
Hi guys,
I'd like to use Eclipse Juno SR2 on my Oracle Enterprise Linux 5.5 (OEL is based on Red Hat ).
I've unzipped my eclipse tar into /opt/eclipse and I've installed tomcat 7.0.12 into /opt/apache-tomcat-7.0.12 .
Tomcat works fine and I'm able to use the manager and deploy a war.
In my ZK(Java) Project I'm not able to use the Run or Debug Eclipse command because I'm getting the following error: "Server Tomcat v7.0 Server at localhost failed to start".
I'm not able to investigate and solve this error.
Could you help me?
Tia.
Re: Unable to start Tomcat [message #1024054 is a reply to message #1023998] Mon, 25 March 2013 18:13 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 3/25/2013 10:02 AM, Simone Sarzano wrote:
> Hi guys,
> Could you help me?
> Tia.
Your question belongs in the Eclipse web tools plaform forum.
Re: Unable to start Tomcat [message #1024347 is a reply to message #1024054] Tue, 26 March 2013 06:13 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Which JRE are you using? Is it the same one you're set up the project within Eclipse to use? What is a "ZK(Java) Project" and are you able to create an empty Dynamic Web Project, make it the only project associated to the Tomcat instance, and start that? Does anything show up in the Console View or your Error Log?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Unable to start Tomcat [message #1027753 is a reply to message #1024347] Wed, 27 March 2013 11:23 Go to previous message
Weronika Kuna is currently offline Weronika KunaFriend
Thanks for an insightful post. These tips are really helpful. Again thanks for sharing your knowledge with us.Keep up the good work.
Previous Topic:seastrandwntr@gmail.com
Next Topic:"No more handles" in Windows 7 64 bits
Current Time: Tue Apr 24 03:25:35 GMT 2018
Powered by FUDForum. Page generated in 0.03627 seconds
