| VJET JS runtime [message #1019643] |
Sat, 16 March 2013 03:51 |
Björn Harrtell Messages: 1 Registered: March 2013 |
Junior Member |
I'm interested in using VJET java to javascript to convert a rather large Java project and it's going quite well - I've successfully used org.eclipse.vjet.dsf.javatojs.cli.Java2Vjo to convert all classes to VJET javascript types.
However, I'm a bit lost when it comes to using the output. I'm not sure I'm finding the correct runtime. I've tried using the various VjBootstrap*.js files in core/org.eclipse.vjet.core.vjodef/src/org/eclipse/vjet/vjo but some things seem missing implementation - for instance vjo.loader.load? If async loading isn't done yet, is there some way to create a static build of the output? Loading the output manually is hard because of complex dependencies.
FUDForum. Page generated in 0.01586 seconds
