Home » Eclipse Projects » Plugin Development Environment (PDE) » Syntax Color Comment Blocks Inside Comment(How Do I Syntax Color Comment Blocks Inside Comment)
Syntax Color Comment Blocks Inside Comment [message #1019365] Fri, 15 March 2013 14:49 Go to next message
Patrick Vane is currently offline Patrick VaneFriend
I am making a plugin voor UnrealScript and I found out that in UnrealScript you can have comment blocks inside comment blocks.
In other words, the amount of
have to match the
/* and /**
in order to close a block.
Example:
            also inside comment block
        still inside comment block
    outside comment blocks
My question is, how do you do this with Eclipse?
I am currently using this, but it doesn't work (it ignores comment block openings when inside a comment block, so the first comment block ending will end every comment block):
    import java.util.ArrayList;
    import org.eclipse.jface.text.rules.EndOfLineRule;
    import org.eclipse.jface.text.rules.ICharacterScanner;
    import org.eclipse.jface.text.rules.IPredicateRule;
    import org.eclipse.jface.text.rules.IToken;
    import org.eclipse.jface.text.rules.IWordDetector;
    import org.eclipse.jface.text.rules.MultiLineRule;
    import org.eclipse.jface.text.rules.RuleBasedPartitionScanner;
    import org.eclipse.jface.text.rules.SingleLineRule;
    import org.eclipse.jface.text.rules.Token;
    import org.eclipse.jface.text.rules.WordRule;
    import com.patrick_vane.unrealscript.editor.constants.TagConstant;
    public class PartitionScanner extends RuleBasedPartitionScanner
        private IToken commentLine  = new Token( TagConstant.COMMENT_LINE );
        private IToken commentBlock = new Token( TagConstant.COMMENT_BLOCK );
        private IToken docsBlock    = new Token( TagConstant.DOCS );
        private IToken string       = new Token( TagConstant.STRING );
        public int commentBlockCount = 0;
        public PartitionScanner()
            ArrayList<IPredicateRule> rules = new ArrayList<IPredicateRule>();
            rules.add( new EndOfLineRule("//", commentLine) );
            rules.add( new SingleLineRule("\"", "\"", string, '\\') );
            rules.add( new SingleLineRule("'", "'", string, '\\') );
            rules.add( new EmptyCommentRule(commentBlock) );
            rules.add( new MultiLineRule("/**", "*/", docsBlock, (char)0, true) );
            rules.add( new MultiLineRule("/*", "*/", commentBlock, (char)0, true) );
            setPredicateRules( rules.toArray(new IPredicateRule[0]) );
        private static class EmptyCommentRule extends WordRule implements IPredicateRule
            private IToken successToken;
            public EmptyCommentRule( IToken successToken )
                super
                    new IWordDetector()
                        public boolean isWordStart( char c )
                            return (c == '/');
                        public boolean isWordPart( char c )
                            return ((c == '*') || (c == '/'));
                this.successToken = successToken;
                addWord( "/**/", successToken );
            public IToken evaluate( ICharacterScanner scanner, boolean resume )
                return super.evaluate( scanner );
            public IToken getSuccessToken()
                return successToken;
Re: Syntax Color Comment Blocks Inside Comment [message #1021841 is a reply to message #1019365] Wed, 20 March 2013 19:22 Go to previous message
Are these forums dead or something?
Previous Topic:How execute actions after content assist selection
Next Topic:Feature version qualifiers and Git
Current Time: Sun May 27 19:52:28 GMT 2018
Powered by FUDForum. Page generated in 0.02162 seconds
