Home » Modeling » Epsilon » Re: Epsilon Tools
Re: Epsilon Tools [message #13831] Wed, 11 March 2009 09:50 Go to next message
Louis Rose is currently offline Louis Rose
Hi Lishan,
I've copied this to the Epsilon newsgroup, so other users can read the
discussion.
Comments below.
Lishan Simone Harbird wrote:
> Hi Louis,
> Im trying to set up and use an Epsilon Tool from a wizard.
> I have an hst package with class mchstTool, I have converted this to a
> plugin.
Great. You'll also need to tell Epsilon that mchstTool is indeed a tool:
1) Open the MANIFEST.MF file in the META-INF directory of the project
that contains your hst package.
2) Click the Dependencies tab, and select Add under Required Plug-in.
Type "org.eclipse.epsilon.common.dt" Click Ok.
3) Click the Extensions tab, and select Add. Scroll down and select the
"org.eclipse.epsilon.common.dt.tool" entry. Click Ok.
4) Select the entry labelled (tool) in the left-hand tree. Type the
fully-qualified path to the class that represents your tool. In your
case, this is: hst.mchstTool
5) Give the tool a defaultName, for example: mchstTool
6) Save the contents of the editor (File | Save).
> In my wizard I have the following code :
> var t : new Native ('hst.mchstTool');
> t.bw.write( "b M e[x==1 ==> a=a+1].P\n" );
> t.bw.flush();
> When I run it I get the following error :
> Type 'hst.mchstTool' not found (..
> I obviously need to do some more things to make the tool visible to the
> wizard but I dont know what.
Your EWL code looks fine.
> I have the Epsilon Tool documentation but I dont understand what it is
> saying to do.
I'll update the documentation with some more instructions, and I'll see
if Dimitrios wants to change anything too.
> Your help is greatly appreciated.
> Thanks
> Lishan
Louis.
Louis Rose
Research Student
Department of Computer Science,
University of York,
Heslington, York, YO10 5DD, United Kingdom.
+44 1904 434762
Twitter: @louisrose
Re: Epsilon Tools [message #14388 is a reply to message #13831] Wed, 11 March 2009 11:49 Go to previous message
> > Hi Louis,
<snip>
> > saying to do.
We've updated the Epsilon Tools documentation. New version available at:
http://www.eclipse.org/gmt/epsilon/doc/EpsilonTools.pdf
Louis.
Louis Rose
Research Student
University of York,
+44 1904 434762
Twitter: @louisrose
Re: Epsilon Tools [message #566052 is a reply to message #13831] Wed, 11 March 2009 11:49 Go to previous message
> > Hi Louis,
<snip>
> > saying to do.
Louis.
Louis Rose
Research Student
University of York,
+44 1904 434762
Twitter: @louisrose
Previous Topic:Re: Epsilon Tools
Next Topic:AbstractEmfModel#store exception due to unmapped path
Current Time: Tue May 21 10:18:59 EDT 2013
Powered by FUDForum. Page generated in 0.01776 seconds
