Home » Language IDEs » CDT » Deleted text re-inserted(Deleted text gets randomly inserted somewhere else in the file)
Deleted text re-inserted [message #1003616] Mon, 21 January 2013 11:12 Go to next message
Steven Duquette is currently offline Steven Duquette
I had no luck searching for my exact problem.
I am using Eclipse Indigo with the CDT tools. I have it running in a VM (VMWare Workstation 7) running a CentOS 5.5 guest.(Windows 7 host)
What happens is, very randomly, when I delete some text, it will end up somewhere else in the file. I usually do not even notice that this has happened until I try to compile and get a ton of errors.
This may also occur if I cut/copy and paste some text. So it almost seems to randomly grab text from the clipboard.
The only other point of reference I have is that I also use Indigo on Windows for Java development and have never seen this problem.
Has anyone experienced this?
Steve
Re: Deleted text re-inserted [message #1003902 is a reply to message #1003616] Tue, 22 January 2013 02:58 Go to previous message
Axel Mueller is currently offline Axel Mueller
Do you have installed any clipboard tool (e.g. Klipper)?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=153809
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:Binary not found error
Next Topic:Unresolved References
Current Time: Sun May 26 04:20:53 EDT 2013
Powered by FUDForum. Page generated in 0.01533 seconds
