Home » Newcomers » Newcomers » Error "'-b' must come at the start of the command line" crosscompiling on eclipse
Error "'-b' must come at the start of the command line" crosscompiling on eclipse [message #1001316] Wed, 16 January 2013 08:25 Go to next message
J C is currently offline J C
I'm trying to cross-compile a C++ project for arm architecture using Eclipse, the issue is that I was retrieved an error while cross-compiling which is the following:
make pre-build main-build
export ac_cv_func_malloc_0_nonnull=yes
Building file: ../tests/utils/TestUtils.cpp
Invoking: Cross G++ Compiler
arm-mv5sft-linux-gnueabi-g++ -I/usr/include/c++/4.6/i686-linux-gnu/64/bits -I/usr/include/libxml2 -I/usr/include/c++/4.6/bits -I/usr/include/c++/4.6.3/i686-linux-gnu/64/bits -I/usr/include/c++/4.6.3/i686-linux-gnu -I/usr/include/c++/4.6/i686-linux-gnu -I/usr/include/c++/4.6 -I/usr/include -O0 -g3 -Wall -m32 -c -fmessage-length=0 -build=i486-build_pc-linux-gnu -host=i686-linux -target=arm-mv5sft-linux-gnueabi -lpthread -v -MMD -MP -MF"tests/utils/TestUtils.d" -MT"tests/utils/TestUtils.d" -o "tests/utils/TestUtils.o" "../tests/utils/TestUtils.cpp"
arm-mv5sft-linux-gnueabi-g++: '-b' must come at the start of the command line
make: *** [tests/utils/TestUtils.o] Error 1
I'm sure that the problem yields in the fact that eclipse doesn't set the -b command when compiling but I don't know how to pass this command to the compiler, any suggestion?
Thanks in advance,
[Updated on: Wed, 16 January 2013 08:26]
Report message to a moderator
Re: Error "'-b' must come at the start of the command line" crosscompiling on ecli [message #1001354 is a reply to message #1001316] Wed, 16 January 2013 09:46 Go to previous message
Russell Bateman is currently offline Russell Bateman
On 1/16/2013 6:25 AM, J C wrote:
> I'm trying to cross-compile ibrdtn for arm architecture using Eclipse,
> is the following:
> line
> Thanks in advance,
Sticky post at top of forum:
http://www.eclipse.org/forums/index.php/t/161206/
Previous Topic:Desktop application in juno
Next Topic:no connetct CVS repository /cvsroot/eclipse
Current Time: Sat May 18 22:53:18 EDT 2013
Powered by FUDForum. Page generated in 0.05465 seconds
