Home » Eclipse Projects » BIRT » Assigning selected drop down list value to report parameter
Assigning selected drop down list value to report parameter [message #995231] Sat, 29 December 2012 13:17 Go to next message
Prachi Pradhan is currently offline Prachi PradhanFriend
I am new to BIRT reports & i am using birt 3.7 version. I want to create one drop down list & depending on that selected value, table values will get changed.
I have created that combo list using HTML javascript. Is it ppossible to set that selected value to report parameters in HTML javascript only?
I have attached my code
Prachi Pradhan
Re: Assigning selected drop down list value to report parameter [message #995980 is a reply to message #995231] Mon, 31 December 2012 17:51 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
So, you're wanting to have a drop down in your report to allow the user to re-run? If so, you simply need to build the URL of the report, with the selected parameter and re-run the report. Let me know.
Michael
Developer Evangelist, Silanis
Previous Topic:Importing package starting with country code in
Next Topic:Send post-request to Birt report viewer on tomcat behind webserver
Current Time: Wed May 23 15:12:19 GMT 2018
Powered by FUDForum. Page generated in 0.01803 seconds
