Home » Modeling » ATL » how to match "packageImport" element in class diagram
how to match "packageImport" element in class diagram [message #987539] Tue, 27 November 2012 05:06 Go to next message
Beatus Ding is currently offline Beatus DingFriend
I'm trying to transform uml diagram to self-defined "unify" file with ATL.A simple class diagram like this
<xmi:XMI xmi:version="20110701" xmlns:xmi="http://www.omg.org/spec/XMI/20110701" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:profile="http:///schemas/profile/_v1QCwDSdEeK5yc5OykOa7Q/6" xmlns:uml="http://www.eclipse.org/uml2/4.0.0/UML" xsi:schemaLocation="http:///schemas/profile/_v1QCwDSdEeK5yc5OykOa7Q/6 model.profile.uml#_v1Qp0DSdEeK5yc5OykOa7Q">
  <uml:Model xmi:id="_xY8XkDdlEeKttLPFIKJkEA" name="model">
    <packageImport xmi:id="_A78LYDdmEeKttLPFIKJkEA">
      <importedPackage xmi:type="uml:Model" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
    </packageImport>
  </uml:Model>
</xmi:XMI>
and the corresponding transformed "unify" file like this:
<?xml version="1.0" encoding="ISO-8859-1"?>
<unify:Model xmlns:unify="http://xxx/unify" unify:name="model" unify:id="_xY8XkDdlEeKttLPFIKJkEA">
  <unify:entity unify:id="_A78LYDdmEeKttLPFIKJkEA">
    <unify:subentity unify:type="uml:Model" unify:href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
  </unify:entity>
</unify:Model>
But now I don't know how to match the "packageImport" in the ATL rule,the same problem exists in "ownedAttribute" and "lowerValue" element(not list above).Who can give some suggestion,any help will be appreciated.
Re: how to match "packageImport" element in class diagram [message #987581 is a reply to message #987539] Tue, 27 November 2012 09:09 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
You have to look at the UML metamodel.
The packageImport eReference is of type PackageImport.
So you can specify a rule on UML!PackageImport in order to transform it to what you want.
Re: how to match "packageImport" element in class diagram [message #987785 is a reply to message #987581] Wed, 28 November 2012 07:42 Go to previous messageGo to next message
I have the metamodel,but I donot know how to match the element in atl,can you give me a simple example,or can you recommend some references,thanks a lot~
Re: how to match "packageImport" element in class diagram [message #1229900 is a reply to message #987785] Fri, 10 January 2014 13:47 Go to previous messageGo to next message
Chris BaileyFriend
Had the same problem here,
Almost resolved it via the following,
where:
UMLPRIM : UML is the input for the UML Primitives library which you can download from here.
create OUT: UML from IN: saafABAC, PRO : UML, UMLPRIM : UML;
rule createModel {
	from
		s: saafABAC!AbacModel
	to
		t: UML!Model(
			name <- 'rbacDSMLmodel',
			packageImport <- thisModule.getUMLPrimitivePackage(s)
unique lazy rule getUMLPrimitivePackage{
	from
	to
		t: UML!PackageImport(
			importedPackage <- UML!Package.allInstances()->select(e|e.name = 'PrimitiveTypes')->first()
This results in:
  <uml:Model xmi:id="_Wx2IEHn0EeO6P9DYsG50AA" name="rbacDSMLmodel">
    <packageImport xmi:id="_Wx2IEXn0EeO6P9DYsG50AA">
      <importedPackage xmi:type="uml:Model" href="../models/UMLPrimitiveTypes.library.uml#_0"/>
    </packageImport>
   </uml:Model>
As for PATHMAP i'm not sure how to set this yet... if anyone knows I'd be grateful Cool I need to create a relative pathmap like: pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0
Re: how to match "packageImport" element in class diagram [message #1250815 is a reply to message #1229900] Wed, 19 February 2014 16:29 Go to previous message
Ronan B is currently offline Ronan BFriend
For the package import you should have a rule like this...
rule CopyPackageImport {
from
s : UML!PackageImport(s.oclIsTypeOf(UML!PackageImport))
to
t : UML!PackageImport
--eAnnotations <- s.eAnnotations,
ownedComment <- s.ownedComment,
importedPackage <- s.importedPackage,
importingNamespace <- s.importingNamespace,
visibility <- s.visibility
then of course the element having the package import should have the following in its rule definition:
packageImport <- s.packageImport
Ronan
Previous Topic:[ATL] serialise xmi to specific format
Next Topic:UML meta-model access
Current Time: Mon Feb 19 11:47:56 GMT 2018
Powered by FUDForum. Page generated in 0.01787 seconds
