Eclipse 3.1 on WinXP [message #141771] |
Mon, 06 March 2006 21:05 |
Originally posted by: rustycanadian.hotmail.com
Hi all,
I'm trying to get Eclipse working on my work machine and I'm having the
single dumbest issue I've ever encountered.
When I try to run Eclipse using eclipse.exe, it says "Required Java
version: 1.4.1. Available: 1.3.1_01." but I've already installed Java 2
RE, SE v1.4.2_11.
However, if I double-click startup.jar, Eclipse opens without errors.
I'm just curious if anyone has any thoughts. I like using Eclipse as an
editor fo PHP, and it runs fine at home. But apparently I have issues
with something.
Any suggestions are appreciated.
Jay
Re: Eclipse 3.1 on WinXP [message #142214 is a reply to message #142110] |
Wed, 08 March 2006 16:39 |
I'd like to thank both of you for your answers.
As Chris suspected, it was caused by statements entered by Oracle into my
system path. Once I removed them, Eclipse started up fine.
In case anyone wonders, I removed the following:
C:\Program Files\Oracle\jre\1.1.8\bin;
Thanks for your help,
Jay
FUDForum. Page generated in 0.03193 seconds
