Home » Modeling » EMF » Before executing AddCommand check for duplicate EKey or run validation
Before executing AddCommand check for duplicate EKey or run validation [message #921916] Mon, 24 September 2012 14:51 Go to next message
John M. is currently offline John M.Friend
I have created an AddCommand and I don't want to execute it, if it would cause a violation of a constraints.
In general I think there are two ways to approach it:
- Check the keys for the new key
- run the generated validator
I can't find the key listing for the first way.
For the second way I don't know how to get the context.
Thanks for any advices.
Re: Before executing AddCommand check for duplicate EKey or run validation [message #921971 is a reply to message #921916] Mon, 24 September 2012 15:56 Go to previous messageGo to next message
John,
Comments below.
On 24/09/2012 4:51 PM, John M. wrote:
> Hello,
The validator will only run against the model in its current state, so
until you actually add it, you can't check if the model with that added
is invalid.
Why not? The add command knows where it's doing the add, i.e, the owner
of the command.
I don't see how you'd get the second way to work.
Re: Before executing AddCommand check for duplicate EKey or run validation [message #922777 is a reply to message #921971] Tue, 25 September 2012 10:23 Go to previous messageGo to next message
> of the command.
So I have manually to iterate over all and check if the key is contained?
I thought there is perhaps a list of used eKeys or something similar.
Re: Before executing AddCommand check for duplicate EKey or run validation [message #922882 is a reply to message #922777] Tue, 25 September 2012 12:25 Go to previous message
John,
No, there isn't.
>> owner of the command.
Previous Topic:EMF Editor Menu isEnabled
Next Topic:Why MetamodelPackage.Literals.Type_Attribute...
Current Time: Thu Apr 19 19:59:09 GMT 2018
Powered by FUDForum. Page generated in 0.01756 seconds
