| Unresolved inclusion problem, [message #921122] |
Sun, 23 September 2012 17:23 |
James Salisbury Messages: 2 Registered: September 2012 |
Junior Member |
I am trying to use the modbus library with some new code, the modbus library and the new code are in seperate projects in the same workspace. The new code is stored in the directory tree within the workspace, the library code is held outside the workspace. I can get the library to complile but I get unresolved inclusion messagages when I try to use the library in the new code. When I go F3 to look at the declaration of the problem functions it displayes the code, so at some level it understands what I am trying to do. What am I doing wrong with my libraries?
I have attached the workspace and the library.
22:51:16 **** Build of configuration Default for project libmodbus-3.0.3 ****
make all
make all-recursive
make[1]: Entering directory `/home/james/projects/archive/libmodbus-3.0.3'
Making all in src
make[2]: Entering directory `/home/james/projects/archive/libmodbus-3.0.3/src'
CC modbus.lo
CC modbus-data.lo
CC modbus-rtu.lo
CC modbus-tcp.lo
CCLD libmodbus.la
make[2]: Leaving directory `/home/james/projects/archive/libmodbus-3.0.3/src'
Making all in doc
make[2]: Entering directory `/home/james/projects/archive/libmodbus-3.0.3/doc'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/james/projects/archive/libmodbus-3.0.3/doc'
Making all in tests
make[2]: Entering directory `/home/james/projects/archive/libmodbus-3.0.3/tests'
make all-am
make[3]: Entering directory `/home/james/projects/archive/libmodbus-3.0.3/tests'
CC bandwidth-server-one.o
CCLD bandwidth-server-one
CC bandwidth-server-many-up.o
CCLD bandwidth-server-many-up
CC bandwidth-client.o
CCLD bandwidth-client
CC random-test-server.o
CCLD random-test-server
CC random-test-client.o
CCLD random-test-client
CC unit-test-server.o
CCLD unit-test-server
CC unit-test-client.o
CCLD unit-test-client
CC version.o
CCLD version
make[3]: Leaving directory `/home/james/projects/archive/libmodbus-3.0.3/tests'
make[2]: Leaving directory `/home/james/projects/archive/libmodbus-3.0.3/tests'
make[2]: Entering directory `/home/james/projects/archive/libmodbus-3.0.3'
make[2]: Leaving directory `/home/james/projects/archive/libmodbus-3.0.3'
make[1]: Leaving directory `/home/james/projects/archive/libmodbus-3.0.3'
22:51:19 Build Finished (took 3s.75ms)
22:22:11 **** Incremental Build of configuration Debug for project meter_code ****
make all
Building target: meter_code
Invoking: GCC C Linker
gcc -L"/home/james/projects/archive/libmodbus-3.0.3" -L"/home/james/projects/archive/libmodbus-3.0.3/src" -L/home/james/projects/archive/libmodbus-3.0.3/src -L/home/james/projects/archive/libmodbus-3.0.3 -o "meter_code" ./src/meter_code.o
./src/meter_code.o: In function `main':
/home/james/projects/meter_projects/meter_code/Debug/../src/meter_code.c:85: undefined reference to `modbus_new_rtu'
/home/james/projects/meter_projects/meter_code/Debug/../src/meter_code.c:86: undefined reference to `modbus_set_slave'
/home/james/projects/meter_projects/meter_code/Debug/../src/meter_code.c:87: undefined reference to `modbus_read_input_registers'
/home/james/projects/meter_projects/meter_code/Debug/../src/meter_code.c:103: undefined reference to `modbus_close'
/home/james/projects/meter_projects/meter_code/Debug/../src/meter_code.c:104: undefined reference to `modbus_free'
collect2: ld returned 1 exit status
make: *** [meter_code] Error 1
[Updated on: Sun, 23 September 2012 17:55] Report message to a moderator
FUDForum. Page generated in 0.01373 seconds
