Home » Modeling » Epsilon » [Eugenia] Generate GMF ... does nothing!?
Re: [Eugenia] Generate GMF ... does nothing!? [message #11405 is a reply to message #11332] |
Fri, 06 February 2009 09:45 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Michael,
I'm not really sure what might be going wrong. I know that quite a few
people have been using EuGENia but there have been no similar problems.
The only thing I could suggest is to start Eclipse via the command
line and see if any stacktrace shows up there...
Dimitris
Michael Moser wrote:
> Hi - I wanted to give Eugenia a try but ran into a problem (or bug?):
> I downloaded/installed Epsilon from
> http://download.eclipse.org/modeling/gmt/epsilon/updates/ and then
> exactly followed the screencast at
> http://www.eclipse.org/gmt/epsilon/cinema/Eugenia.htm.
> I copy-pasted the File system example found a
> http://epsilonlabs.wiki.sourceforge.net/EuGENia into the Emfatic editor
> as suggested and was able to create the .ecore file from the .emf file -
> no problems.
> I then created the .genmodel file as instructed and next issued the
> Eugenia => Generate GMF tool, map and graph models command.
> But, alas, in contrast to the screencast nothing happens here, i.e.
> there are no .gmf* files showing up in the model folder (nor anywhere
> else).
> What am I missing? This is using Eclipse 3.4.1 (Ganymede) and Epsilon
> 0.8.3.
> There are no problems, i.e. all files seem fine and have no syntax errors.
> I also checked the eclipse log file and it show no entry.
> Hints, ideas, suggestions?
> Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #11479 is a reply to message #11442] |
Fri, 06 February 2009 12:09 |
Hi Michael,
You seem to have done everything correctly... Would you mind creating a
zip of the project and sending it to me (either through the newsgroup or
in private)?
Dimitrios
> Dimitris Kolovos wrote:
>> Hi Michael,
>> problems. The only thing I could suggest is to start Eclipse via the
>> command line and see if any stacktrace shows up there...
>> Cheers,
>> Dimitris
> Nope - nothing appears:
> C:\>C:\eclipse_3.4.1\eclipse\eclipse.exe -clean -vm
> C:\IBMJSDK1.6.0\bin\javaw.exe -vmargs -Xms50M -Xmx750M -Xss512k
> -Duser.language=en_US
> C:\>
> Eclipse's .log-file also show nothing relevant (a couple of key binding
> conflicts and "Unable to retrieve system properties" which it has shown
> on my system already for ages...).
> I then decided to try a last time from square zero:
> I painstakingly followed the installation guide at
> http://www.eclipse.org/gmt/epsilon/doc/P2InstallationGuide.p df, i.e. I
> 1. I downloaded eclipse-ganymede-modeling-SR1
> 2. I added http://download.eclipse.org/modeling/gmt/epsilon/updates/ as
> new download site
> 3. from that installed Epsilon (the entire thing)
> 4. lastly, I installed Emfatic from
> http://www.scharf.gr/eclipse/emfatic/update/.
> I then directed the new eclipse installation to the existing project,
> containing the filesystem.emf file and restarted from there, i.e.
> recreated the .ecore file, from that the .genmodel file, from that did a
> Generate All.
> Finally I selected the filesystem.ecore again and issued the Eugenia =>
> Generate GMF... and - again - nothing! And also again: nothing in the
> log nor on the console. :-(
> Is there anything else I could provide or try to debug this?
> Michael
> PS.: I must have some bad aura for eclipse projects...
Re: [Eugenia] Generate GMF ... does nothing!? [message #564826 is a reply to message #11332] |
Hi Michael,
Dimitris
> no problems.
> else).
> 0.8.3.
> Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #564853 is a reply to message #11442] |
Hi Michael,
in private)?
Dimitrios
>> Hi Michael,
>> Cheers,
>> Dimitris
> C:\>
> new download site
> Generate All.
> Michael
Current Time: Fri Mar 29 15:31:59 GMT 2024
Powered by FUDForum. Page generated in 0.02627 seconds
