Home » Eclipse Projects » Rich Client Platform (RCP) » Query on SWT Browser response messages(Query on SWT Browser response messages)
Query on SWT Browser response messages [message #905962] Fri, 31 August 2012 07:28 Go to next message
Rahul Chandrashekar is currently offline Rahul Chandrashekar
Member
Hello Together,
http://open-services.net/bin/view/Main/OslcCoreSpecification?sortcol=table;up=#Delegated_User_Interface_Dialogs
On executing the URL with Post message protocol, we are able to get the requested requirements and when we select the requirement it give us a table which contains the id and the requirement label, in this page there are 2 button options are available (Ok and Cancel).
When we select Ok, it seems OSLC should respond with a message . but we are not able to get this message on our application.
We are currently use SWT BROWSER widget to load the above URL
kindly let us know how can we proceed on the same.
Re: Query on SWT Browser response messages [message #1024051 is a reply to message #905962] Mon, 25 March 2013 14:14 Go to previous messageGo to next message
Alina Julean is currently offline Alina Julean
I am seeing the same issue. Using Eclipse 3.7 with IE8. (actually IE10 with compatibility mode set to 8). When working with IE9 I cannot pass the login page.
Were you able to find a solution ?
[Updated on: Mon, 25 March 2013 21:15] by Moderator
Report message to a moderator
Re: Query on SWT Browser response messages [message #1024515 is a reply to message #905962] Tue, 26 March 2013 04:21 Go to previous messageGo to next message
Simon SSC is currently offline Simon SSC
Member
you should have a look at the evaluate method of the org.eclipse.swt.browser.Browser
This method can be used to get the content by using JavaScript, which is returned by the server.
See the JavaDoc to find out how it works:
http://help.eclipse.org/galileo/topic/org.eclipse.platform.doc.isv/reference/api/org/eclipse/swt/browser/Browser.html#evaluate(java.lang.String)
Simon
Current Time: Wed May 22 11:36:58 EDT 2013
Powered by FUDForum. Page generated in 0.01791 seconds
