Register user-defined ModelSnippet [message #903886] |
Mon, 27 August 2012 06:45 |
Hi all,
I was trying to register a ModelSnippet for the NotationModel in order to
register the very same adapter for the Notation Model as it has been done
for the Uml Model. However, even though the Snippet is registered (i.e. it
is retrieved from the extension registry and associated to the Notation
Model), it is never invoked when the ModelSet starts the associated snippets
for the contained model.
Actually, it is the case that the snippets list for the Notation Model is
empty after the ModelsReader has instantiated it, although it was
successfully retrieved from the extension registry and apparantly loaded.
My plugin.xml looks like this (I'm using 0.8.2 but the way to register a
ModelSnippet has not changed in 0.9.0):
<extension
point="org.eclipse.papyrus.core.model">
<model
classname="org.eclipse.papyrus.resource.notation.NotationModel">
<modelSnippet
classname="de.fraunhofer.fokus.testing.fokusmbt.ui.core.integration.papyrus.NotationListenerAdapter">
</modelSnippet>
</model>
<!-- this works -->
<modelSetSnippet
classname="de.fraunhofer.fokus.testing.fokusmbt.ui.core.integration.papyrus.ModelSetSnippet1">
</modelSetSnippet>
</extension>
I gave also a second try and registered a MyUmlSnippet in exactly the same
way the default UmlSnippet was registered, with the same, i.e. no, success.
So, is it possible to supplementary register model snippets? As indicated in
the XML snippet, the ModelSetSnippet worked quite well.
Thanks in advance.
Florian
FUDForum. Page generated in 0.02354 seconds
