Home » Language IDEs » C / C++ IDE (CDT) » Ok, new question. (Where does eclipse install profiles in linux?)
icon8.gif  Ok, new question. [message #903018] Tue, 21 August 2012 16:22 Go to next message
Trever Hillis is currently offline Trever HillisFriend
So if you read my other thread about C++ preferences, or even cdt in general not showing up in the eclipse platform, I have decided teh only why to get these back is from a fresh install.
Just a fresh re-install does nothing. Still not CDT
I sudo apt-get removed EVERY eclipse thing on my computer. I realized that the workspace also has .metadata and .plugins with other files that could be causing it to not load CDT. I purged EVERYTHING again. My workspace is gone, purged, no more. Along with all the eclipse programs.
I go to sudo apt-get install eclipse-cdt
I run eclipse, and what do you know?!?! My workspace is re-created with all teh .metadata and all!! Where is this coming from. What other profiles/files do I need to delete?
Please Help if you can
Trever
Re: Ok, new question. [message #903097 is a reply to message #903018] Tue, 21 August 2012 22:51 Go to previous message
David Wegener is currently offline David WegenerFriend
> Thanks
> Trever
When you run Eclipse, you have to have a workspace. It will will be
filled in when you create it.
Don't install using the repositories for you Linux distribution. They
are not supported by the Eclipse forums. You should remove what you
have installed and download Eclipse from the download page at
Eclipse.org. Unzip it into a directory, point the eclipse.ini to your
JDK VM runtime and you are ready to go.
Previous Topic:Automatic discovery of paths - explanation?
Next Topic:No c++ preferences
Current Time: Fri Apr 20 18:27:51 GMT 2018
Powered by FUDForum. Page generated in 0.01548 seconds
