Home » Eclipse Projects » BIRT » Is it a bug
Is it a bug [message #902303] Thu, 16 August 2012 21:37 Go to next message
DONG YAO is currently offline DONG YAOFriend
In my jsp, I have code like this
<birt:report ...
<birt:param name="orgId" value="${orgId}" />
</birt:report>
the value of ${orgId} is 1|abc|334455
In the report, I system out the parameter "orgId" but only get 1, the first part of the string.
I change the delimeter to $, then the report output 1$abc$334455
What is wrong with using "|" as delimter?
I am using birt 2.6.
Re: Is it a bug [message #902420 is a reply to message #902303] Fri, 17 August 2012 14:23 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
I believe a bug has already been filed on this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=325711
Jason
> <birt:report ...
> </birt:report>
> first part of the string. I change the delimeter to $, then the report
> output 1$abc$334455
> Thanks
Previous Topic:Cross Tab parameter
Next Topic:Grid Display
Current Time: Tue May 22 02:38:02 GMT 2018
Powered by FUDForum. Page generated in 0.02142 seconds
