Re: Unfinished Report [message #902074 is a reply to message #902031] |
Wed, 15 August 2012 18:08 |
What version of BIRT are you using and what app server are you using?
Jason
On 8/15/2012 10:59 AM, Juliane Harbarth wrote:
> Good evening,
> I am currently having problems when displaying a report that used to
> work. The report uses a custom ODA data source that accesses a database.
> Instead of showing a report consisting of several pages containing data
> read from the database, what I see is just the usual icons that come
> when using the _frameset command and a subsequent line that is 'Showing
> page 1 of'. I have tried with different browsers, among others IE9 and
> Firefox.
> Usually, when there are problems accessing the database, the report is
> not displayed but in the browser window or either in a pop-up there
> comes some complaint about BIRT not being able to deal with a certain
> element in the report which usually is a table connected to a query. But
> currently there is no such response.
> It seems as if the browser waits for the report to finish without
> getting into any timeout. Does anybody have a suggestion what the reason
> for such a behaviour can be?
> Thanks & regards,
> Juliane.
Re: Unfinished Report [message #902256 is a reply to message #902172] |
Thu, 16 August 2012 15:05 |
Juliane,
Does it work when you use the /run mapping instead of the /frameset
mapping? Do you get anything in the birt log? You can set the log
level to FINE in the web.xml.
Jason
On 8/16/2012 4:43 AM, Juliane Harbarth wrote:
> We use Tomcat 6.0.29 and BIRT 261. But there is more to say.
> The WebApp that is deployed below Tomcat is not exactly a BIRT 261
> runtime engine but an App that contains such an engine plus some filters
> that, for example, obtain the report template from a database and move
> it into a temporary Tomcat workspace where the later-to-be-executed BIRT
> engine can see it.
> Also we use Tomcat's redirect mechanism to point to a different URL.
> This alows us to have the WebApps at a different location in the
> installed product and not below the Tomcat folder.
> Don't know whether theses peculiarities matter here, though.
FUDForum. Page generated in 0.03649 seconds
