Home » Eclipse Projects » Eclipse 4 » Use of DI in extension(DependencyInjection and Extensions)
Use of DI in extension [message #898660] Fri, 27 July 2012 06:31 Go to next message
Stefan Wiese is currently offline Stefan WieseFriend
I've created an extension point in plugin a and an extension in plugin b.
The extension has a dependency to ECommandService, EHandlerService and MApplication. All dependencies are null. I tried to inject an IEclipseContext in ctor but it is null.
What do I have to pay attention for when using DependencyInjection in extensions?
Is it in general possible?
Stefan
Re: Use of DI in extension [message #898668 is a reply to message #898660] Fri, 27 July 2012 06:50 Go to previous messageGo to next message
Ah, here's the solution:
When evaluating the extensions simply call ContextInjectionFactory.inject(context);
@Inject
public OpenSearchHandler(ISearchComponent searchComponent, IEclipseContext context, IExtensionRegistry registry)
		IConfigurationElement[] extensions = registry
			.getConfigurationElementsFor("my.own.extensionpoint.definition.searchprovider");
		for (IConfigurationElement extension : extensions)
			LOG.debug("Evaluating extension");
			try
				final Object o = extension.createExecutableExtension("class");
				if (o instanceof SearchProvider)
					SearchProvider searchProvider = (SearchProvider) o;
					LOG.debug("Found SearchProvider --> " + searchProvider.getLabel());
					ContextInjectionFactory.inject(searchProvider, context);
					searchComponent.addSearchProvider(searchProvider);
			catch (CoreException e)
				LOG.error(e);
Stefan
Re: Use of DI in extension [message #898670 is a reply to message #898660] Fri, 27 July 2012 06:52 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
No extension points currently can't use DI. We'd need a special way to
create instances by routing the IEclipseContext to the creation.
IIRC there is a feature request in bugzilla but I can't remember the
name. As a replacement for an extension point one can see
ContextFunctions who can be contributed through DS.
Tom
Am 27.07.12 08:31, schrieb Stefan Wiese:
> extensions? Is it in general possible?
> Stefan
Re: Use of DI in extension [message #898681 is a reply to message #898668] Fri, 27 July 2012 07:52 Go to previous message
Yes that's a solution - but it doesn't allow to use constructor
injection, and @PostConstruct. I'd like to that the IExtensionRegistry
injected here is using the IEclipseContext to create instances using
ContextInjectionFactory.make.
Tom
Am 27.07.12 08:50, schrieb Stefan Wiese:
> @Inject
> try
> final Object o =
> context);
> LOG.error(e);
> Stefan
Previous Topic:(Announce) "Jeeeyul's Eclipse Themes" is Updated
Next Topic:Where are the code snippets?
Current Time: Tue Jan 23 22:16:03 GMT 2018
Powered by FUDForum. Page generated in 0.01877 seconds
