Home » Modeling » Graphiti » Connections to a Polygon figure are not properly connected to its borders
Connections to a Polygon figure are not properly connected to its borders [message #897647] Tue, 24 July 2012 21:41 Go to next message
Surya Kathayat is currently offline Surya KathayatFriend
Member
As you can see in the figure, connections to a Polygon figure are not properly connected to the borders. I have (in the code below) an invisible rectangle that encloses a polygon and a text below it.
Can anyone give me some pointers?
Best Regards.
Surya
index.php/fa/10847/0/
public class ConditionTaskAddFeature extends AbstractAddShapeFeature implements IAddFeature {
	public static final int INVISIBLE_RECT_BUTTOM = 20;
	private static final IColorConstant CLASS_TEXT_FOREGROUND = new ColorConstant(51, 51, 153);
	private static final IColorConstant CLASS_FOREGROUND = new ColorConstant(255, 102, 0);
	private static final IColorConstant CLASS_BACKGROUND =  new ColorConstant(255, 204, 153);
	public ConditionTaskAddFeature(IFeatureProvider fp) {
		super(fp);
	public boolean canAdd(IAddContext context) {
		if (context.getNewObject() instanceof ConditionalTask) {
			if (context.getTargetContainer() instanceof Diagram) {
				return true;
		return false;
	public PictogramElement add(IAddContext context) {
		ConditionalTask conditionTask = (ConditionalTask) context.getNewObject();
		Diagram targetDiagram = (Diagram) context.getTargetContainer();
		// CONTAINER SHAPE WITH ROUNDED RECTANGLE
		IPeCreateService peCreateService = Graphiti.getPeCreateService();
		ContainerShape containerShape = peCreateService.createContainerShape(targetDiagram, true);
		// define a default size for the shape
		int width = context.getWidth() <= 0 ? 80 : context.getWidth();
		int height = context.getHeight() <= 0 ? 80 : context.getHeight();
		Polygon diamond;
		IGaService gaService = Graphiti.getGaService();
			// create invisible reactangle
			 Rectangle invisibleRectangle = gaService.createInvisibleRectangle(containerShape);
			 gaService.setLocationAndSize(invisibleRectangle, context.getX(), context.getY(), width, height + INVISIBLE_RECT_BUTTOM);
			// create polygon and set graphics algorithm
			int xy[] = new int[] {40,0,80,40,40,80,0,40};
			diamond = gaService.createPolygon(invisibleRectangle, xy);
			diamond.setParentGraphicsAlgorithm(invisibleRectangle);
			diamond.setForeground(manageColor(IColorConstant.LIGHT_BLUE));
			diamond.setBackground(manageColor(IColorConstant.LIGHT_BLUE));
			diamond.setLineWidth(2);
			gaService.setLocationAndSize(diamond, 0, 0, width, height);
			// if added Class has no resource we add it to the resource
			// of the diagram
			// in a real scenario the business model would have its own resource
			if (conditionTask.eResource() == null) {
				getDiagram().eResource().getContents().add(conditionTask);
			// create link and wire it
			link(containerShape, conditionTask);
		// IMAGE
			// create shape for Image
			Shape shape = peCreateService.createShape(containerShape, false);
			Image image = gaService.createImage(shape, ImageUtil.IMG_ORDEREDTASK);
			gaService.setLocationAndSize(image, 30, 30, 20, 20);
		// SHAPE WITH TEXT
			// create shape for text
			// create and set text graphics algorithm
			Text text = gaService.createDefaultText(getDiagram(), shape, conditionTask.getName());
			text.setForeground(manageColor(CLASS_TEXT_FOREGROUND));
			text.setHorizontalAlignment(Orientation.ALIGNMENT_CENTER);
			text.setVerticalAlignment(Orientation.ALIGNMENT_CENTER);
			gaService.setLocationAndSize(text, 10, height, width-20, 20);
			link(shape, conditionTask);
		// add a chopbox anchor to the shape
		peCreateService.createChopboxAnchor(containerShape);
		// call the layout feature
                 layoutPictogramElement(containerShape);
		return containerShape;
  • Attachment: decision.gif
    (Size: 8.06KB, Downloaded 509 times)
Re: Connections to a Polygon figure are not properly connected to its borders [message #897964 is a reply to message #897647] Wed, 25 July 2012 14:10 Go to previous messageGo to next message
Matthias Gorning is currently offline Matthias GorningFriend
Member
If you use invisible rectangles it's a little bit tricky.
You toolbehaviour provider must override the method
public GraphicsAlgorithm getChopboxAnchorArea(PictogramElement pe)
If the pe is connected with the ConditionalTask simply return the first child of the invisible rectangle. In this case your diamand polygon.
BR,
Matthias
Re: Connections to a Polygon figure are not properly connected to its borders [message #897995 is a reply to message #897964] Wed, 25 July 2012 15:12 Go to previous message
Member
Thank you again.
Works great.
BR
Surya
Previous Topic:Default Update Feature and Unresolvable Proxies
Next Topic:Resize without resizing subshapes
Current Time: Sun Apr 22 05:22:39 GMT 2018
Powered by FUDForum. Page generated in 0.01550 seconds
