Home » Language IDEs » C / C++ IDE (CDT) » Compilation 32bit on 64bit plateform (advenced)
icon4.gif  Compilation 32bit on 64bit plateform (advenced) [message #895563] Fri, 13 July 2012 15:02 Go to next message
Gary All is currently offline Gary AllFriend
I ve already read the other topics that talk about this subject but it does not help me..
My problem : i can't compile my program for 32bit on a debian which is 64bit
I am using Eclipse c++ btw
I saw Axel Mueller say :
To build 32Bit applications on a 64Bit platform you need:
- gcc/g++ with multilib
- ia32-libs (needed to link and run your application)
- in Eclipse you add -m32 to the compiler and linker flags
I did not have g++-multilib so I installed it by apt-get install g++-multilib. But i dont know if eclipse use the new or the older g++.
I hadnt got ia32-libs either so I did apt-get ia32-libs too.
But i dont know how to use it..
And Ive read on the internet that the option -m32 in project/properties/c/c++build/settings/GCC C++ Compiler/Command should work
But even though I tried it, I cannot make it work.
Any help would be appreciated
Thanks.
Re: Compilation 32bit on 64bit plateform (advenced) [message #895808 is a reply to message #895563] Mon, 16 July 2012 07:20 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
There is still only one g++ binary. The only difference is that g++ from the g++-multilib can compile for 32 and 64 bit.
You don't have to do anything. The linker and your 32bit application will use the correct libs.
Can you be more specific. What does not work? Any error messages?
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Compilation 32bit on 64bit plateform (advenced) [message #895826 is a reply to message #895808] Mon, 16 July 2012 08:31 Go to previous messageGo to next message
Thanks for ur answer
First, I dont understand how the lib ia32 will be linked to my application if i dont add it in project properties/c++ linker/librairies..
Second, i am working on Debian 64 bit and using the graphic librairy "Foxtool kit" so I install it like this (./configure make make install) but it is compiled for 64bit system so when I compile my application that needs Fox lib (g++ -m32 -L/root/Documents/lib/64bit -o"testfox" ./NotreWindow.o ./main.o -lFOX-1.6) the error message is :
/usr/bin/ld: skipping incompatible /root/Documents/lib/64bit/libFOX-1.6.so when searching for -lFOX-1.6
/usr/bin/ld: skipping incompatible /root/Documents/lib/64bit/libFOX-1.6.a when searching for -lFOX-1.6
/usr/bin/ld: skipping incompatible /usr/local/lib/libFOX-1.6.so when searching for -lFOX-1.6
/usr/bin/ld: skipping incompatible /usr/local/lib/libFOX-1.6.a when searching for -lFOX-1.6
/usr/bin/ld: cannot find -lFOX-1.6
I have compiled Fox in Debian 32bit as well and I import it in my Debian 64bit and I try this :
g++ -m32 -L/root/Documents/lib/32bit -o"testfox" ./NotreWindow.o ./main.o -lFOX-1.6
The error message is :
/root/Documents/lib/32bit/idth(wchar_t) const':
FXFont.cpp:(.text+0x1clibFOX-1.6.a(FXFont.o): In function `FX::FXFont::getCharWf6): undefined reference to `XftTextExtents32'
(999999 errors like that)
The compiler does not recognize anything in the lib..
I dont know how to do it.
Re: Compilation 32bit on 64bit plateform (advenced) [message #895876 is a reply to message #895826] Mon, 16 July 2012 12:16 Go to previous messageGo to next message
Firstly, you have to compile Foxtool kit library as 32bit version on your 64bit host. Have a look at the configure options to see how you can pass gcc compiler flags http://stackoverflow.com/questions/3261909/build-32bit-on-64-bit-linux-using-a-configure-script
Before you ask
- search this forum
- google
Re: Compilation 32bit on 64bit plateform (advenced) [message #895932 is a reply to message #895876] Mon, 16 July 2012 14:34 Go to previous messageGo to next message
When I compile FOX (64 bit standard) it works, I can create an application that uses FOX, perfect.
But, when I add -m32 to complile FOX, the error message appears :
skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.4.5/../../../libGLU.so when searching for -lGLU
I know FOX uses GLU library and i have it in my system but in 64bit version!
It is always the same problem :
I tried to compile my application in 32bit, but I could not because I have FOX in 64bit.
And now I am trying to compile FOX in 32bit, but I cannot because I have GLU in 64bit..
Endless problems..
How I can do it please? There must be a solution.
Re: Compilation 32bit on 64bit plateform (advenced) [message #896114 is a reply to message #895932] Tue, 17 July 2012 09:55 Go to previous messageGo to next message
I have figured out how it works so when i compile FOX in 64bit it works.
But when i want to compile in 32bit the error message appears :
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.4.5/../../../libXft.so when searching for -lXft
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.4.5/../../../libXft.a when searching for -lXft
/usr/bin/ld: skipping incompatible /usr/lib/libXft.so when searching for -lXft
/usr/bin/ld: skipping incompatible /usr/lib/libXft.a when searching for -lXft
/usr/bin/ld: cannot find -lXft
I dont understand why, because in FOX properties/C++build/settings/C++linker/libraries/ I change the path to : /usr/lib32/ (libs given by package ia32-libs)
root@solinnen:~# ls /usr/lib32/libXft.so.2
I dont understand why it tries to link libXft from /usr/lib/libXft.so !
Someone has an idea?
Re: Compilation 32bit on 64bit plateform (advenced) [message #896115 is a reply to message #895932] Tue, 17 July 2012 10:01 Go to previous messageGo to next message
Gary All wrote on Mon, 16 July 2012 16:34
It seems you did not pass "-m32" to the linker. Did you use the configure command line I quoted in my last post? Did you clean up before calling configure?
Before you ask
- search this forum
- google
Re: Compilation 32bit on 64bit plateform (advenced) [message #896119 is a reply to message #896115] Tue, 17 July 2012 10:26 Go to previous messageGo to next message
make all
Building target: libFOX.so
Invoking: GCC C++ Linker
g++ -m32 -L/usr/lib32 -shared -o"libFOX.so"  ./FX4Splitter.o ./FX7Segment.o ./FX885910Codec.o ./FX885911Codec.o ./FX885913Codec.o ./FX885914Codec.o ./FX885915Codec.o ./FX885916Codec.o ./FX88591Codec.o ./FX88592Codec.o ./FX88593Codec.o ./FX88594Codec.o ./FX88595Codec.o ./FX88596Codec.o ./FX88597Codec.o ./FX88598Codec.o ./FX88599Codec.o ./FXAccelTable.o ./FXApp.o ./FXArrowButton.o ./FXBMPIcon.o ./FXBMPImage.o ./FXBZFileStream.o ./FXBitmap.o ./FXBitmapFrame.o ./FXBitmapView.o ./FXButton.o ./FXCP1250Codec.o ./FXCP1251Codec.o ./FXCP1252Codec.o ./FXCP1253Codec.o ./FXCP1254Codec.o ./FXCP1255Codec.o ./FXCP1256Codec.o ./FXCP1257Codec.o ./FXCP1258Codec.o ./FXCP437Codec.o ./FXCP850Codec.o ./FXCP852Codec.o ./FXCP855Codec.o ./FXCP856Codec.o ./FXCP857Codec.o ./FXCP860Codec.o ./FXCP861Codec.o ./FXCP862Codec.o ./FXCP863Codec.o ./FXCP864Codec.o ./FXCP865Codec.o ./FXCP866Codec.o ./FXCP869Codec.o ./FXCP874Codec.o ./FXCURCursor.o ./FXCanvas.o ./FXCheckButton.o ./FXChoiceBox.o ./FXColorBar.o ./FXColorDialog.o ./FXColorList.o ./FXColorNames.o ./FXColorRing.o ./FXColorSelector.o ./FXColorWell.o ./FXColorWheel.o ./FXComboBox.o ./FXComposeContext.o ./FXComposite.o ./FXCursor.o ./FXDC.o ./FXDCPrint.o ./FXDCWindow.o ./FXDLL.o ./FXDataTarget.o ./FXDate.o ./FXDebugTarget.o ./FXDelegator.o ./FXDial.o ./FXDialogBox.o ./FXDict.o ./FXDir.o ./FXDirBox.o ./FXDirDialog.o ./FXDirList.o ./FXDirSelector.o ./FXDockBar.o ./FXDockHandler.o ./FXDockSite.o ./FXDockTitle.o ./FXDocument.o ./FXDragCorner.o ./FXDrawable.o ./FXDriveBox.o ./FXException.o ./FXExpression.o ./FXExtentd.o ./FXExtentf.o ./FXFile.o ./FXFileDialog.o ./FXFileDict.o ./FXFileList.o ./FXFileSelector.o ./FXFileStream.o ./FXFoldingList.o ./FXFont.o ./FXFontDialog.o ./FXFontSelector.o ./FXFrame.o ./FXGIFCursor.o ./FXGIFIcon.o ./FXGIFImage.o ./FXGLCanvas.o ./FXGLCone.o ./FXGLContext.o ./FXGLCube.o ./FXGLCylinder.o ./FXGLObject.o ./FXGLShape.o ./FXGLSphere.o ./FXGLTriangleMesh.o ./FXGLViewer.o ./FXGLVisual.o ./FXGUISignal.o ./FXGZFileStream.o ./FXGradientBar.o ./FXGroupBox.o ./FXHash.o ./FXHeader.o ./FXHorizontalFrame.o ./FXICOIcon.o ./FXICOImage.o ./FXIFFIcon.o ./FXIFFImage.o ./FXIO.o ./FXIcon.o ./FXIconDict.o ./FXIconList.o ./FXIconSource.o ./FXId.o ./FXImage.o ./FXImageFrame.o ./FXImageView.o ./FXInputDialog.o ./FXJPGIcon.o ./FXJPGImage.o ./FXKOI8RCodec.o ./FXKnob.o ./FXLabel.o ./FXList.o ./FXListBox.o ./FXMDIButton.o ./FXMDIChild.o ./FXMDIClient.o ./FXMainWindow.o ./FXMat3d.o ./FXMat3f.o ./FXMat4d.o ./FXMat4f.o ./FXMatrix.o ./FXMemMap.o ./FXMemoryStream.o ./FXMenuBar.o ./FXMenuButton.o ./FXMenuCaption.o ./FXMenuCascade.o ./FXMenuCheck.o ./FXMenuCommand.o ./FXMenuPane.o ./FXMenuRadio.o ./FXMenuSeparator.o ./FXMenuTitle.o ./FXMessageBox.o ./FXObject.o ./FXObjectList.o ./FXOptionMenu.o ./FXPCXIcon.o ./FXPCXImage.o ./FXPNGIcon.o ./FXPNGImage.o ./FXPPMIcon.o ./FXPPMImage.o ./FXPacker.o ./FXPath.o ./FXPicker.o ./FXPipe.o ./FXPoint.o ./FXPopup.o ./FXPrintDialog.o ./FXProgressBar.o ./FXProgressDialog.o ./FXQuatd.o ./FXQuatf.o ./FXRASIcon.o ./FXRASImage.o ./FXRGBIcon.o ./FXRGBImage.o ./FXRadioButton.o ./FXRanged.o ./FXRangef.o ./FXRealSlider.o ./FXRealSpinner.o ./FXRecentFiles.o ./FXRectangle.o ./FXRegion.o ./FXRegistry.o ./FXReplaceDialog.o ./FXRex.o ./FXRootWindow.o ./FXRuler.o ./FXRulerView.o ./FXScrollArea.o ./FXScrollBar.o ./FXScrollPane.o ./FXScrollWindow.o ./FXSearchDialog.o ./FXSeparator.o ./FXSettings.o ./FXShell.o ./FXShutter.o ./FXSize.o ./FXSlider.o ./FXSocket.o ./FXSphered.o ./FXSpheref.o ./FXSpinner.o ./FXSplashWindow.o ./FXSplitter.o ./FXSpring.o ./FXStat.o ./FXStatusBar.o ./FXStatusLine.o ./FXStream.o ./FXString.o ./FXStringDict.o ./FXSwitcher.o ./FXSystem.o ./FXTGAIcon.o ./FXTGAImage.o ./FXTIFIcon.o ./FXTIFImage.o ./FXTabBar.o ./FXTabBook.o ./FXTabItem.o ./FXTable.o ./FXText.o ./FXTextCodec.o ./FXTextField.o ./FXThread.o ./FXToggleButton.o ./FXToolBar.o ./FXToolBarGrip.o ./FXToolBarShell.o ./FXToolBarTab.o ./FXToolTip.o ./FXTopWindow.o ./FXTranslator.o ./FXTreeList.o ./FXTreeListBox.o ./FXTriStateButton.o ./FXURL.o ./FXUTF16Codec.o ./FXUTF32Codec.o ./FXUTF8Codec.o ./FXUndoList.o ./FXVec2d.o ./FXVec2f.o ./FXVec3d.o ./FXVec3f.o ./FXVec4d.o ./FXVec4f.o ./FXVerticalFrame.o ./FXVisual.o ./FXWindow.o ./FXWizard.o ./FXXBMIcon.o ./FXXBMImage.o ./FXXPMIcon.o ./FXXPMImage.o ./fxascii.o ./fxbmpio.o ./fxezquantize.o ./fxfilematch.o ./fxfsquantize.o ./fxgifio.o ./fxicoio.o ./fxiffio.o ./fxjpegio.o ./fxkeyboard.o ./fxkeysym.o ./fxparsegeometry.o ./fxpcxio.o ./fxpngio.o ./fxppmio.o ./fxpriv.o ./fxpsio.o ./fxrasio.o ./fxrgbio.o ./fxtargaio.o ./fxtifio.o ./fxunicode.o ./fxutils.o ./fxwuquantize.o ./fxxbmio.o ./fxxpmio.o ./icons.o ./strtoll.o ./vsscanf.o   -lX11 -lXft -lpng -lGL -lGLU -lXrender -lXext -lrt -lpthread
collect2: ld returned 1 exit status
make: *** [libFOX.so] Erreur 1
I passed the option -m32 to the compilater and linker.
The stronger is that if i delete Xft in in FOX properties/C++build/settings/C++linker/libraries/, FOX is compiled. But in xterm:
g++-4.4 -m32 *.cpp -I /usr/local/include/fox-1.6/ -L ../FOX/Debug/ -lFOX
../FOX/Debug//libFOX.so: undefined reference to `FcFontSetDestroy'
../FOX/Debug//libFOX.so: undefined reference to `FcPatternAddString'
../FOX/Debug//libFOX.so: undefined reference to `XftInit'
../FOX/Debug//libFOX.so: undefined reference to `XftCharExists'
And
g++-4.4 -m32 *.cpp -I /usr/local/include/fox-1.6/ -L ../FOX/Debug/ -lFOX -L/usr/lib32/ -lXft
I have just tried to compile FOX in 64bit with path libraries like /usr/lib32/:
make all
g++ -L/usr/lib32 -shared -o"libFOX.so"  ./FX4Splitter.o ./FX7Segment.o ./FX885910Codec.o ./FX885911Codec.o ./FX885913Codec.o ./FX885914Codec.o ./FX885915Codec.o ./FX885916Codec.o ./FX88591Codec.o ./FX88592Codec.o ./FX88593Codec.o ./FX88594Codec.o ./FX88595Codec.o ./FX88596Codec.o ./FX88597Codec.o ./FX88598Codec.o ./FX88599Codec.o ./FXAccelTable.o ./FXApp.o ./FXArrowButton.o ./FXBMPIcon.o ./FXBMPImage.o ./FXBZFileStream.o ./FXBitmap.o ./FXBitmapFrame.o ./FXBitmapView.o ./FXButton.o ./FXCP1250Codec.o ./FXCP1251Codec.o ./FXCP1252Codec.o ./FXCP1253Codec.o ./FXCP1254Codec.o ./FXCP1255Codec.o ./FXCP1256Codec.o ./FXCP1257Codec.o ./FXCP1258Codec.o ./FXCP437Codec.o ./FXCP850Codec.o ./FXCP852Codec.o ./FXCP855Codec.o ./FXCP856Codec.o ./FXCP857Codec.o ./FXCP860Codec.o ./FXCP861Codec.o ./FXCP862Codec.o ./FXCP863Codec.o ./FXCP864Codec.o ./FXCP865Codec.o ./FXCP866Codec.o ./FXCP869Codec.o ./FXCP874Codec.o ./FXCURCursor.o ./FXCanvas.o ./FXCheckButton.o ./FXChoiceBox.o ./FXColorBar.o ./FXColorDialog.o ./FXColorList.o ./FXColorNames.o ./FXColorRing.o ./FXColorSelector.o ./FXColorWell.o ./FXColorWheel.o ./FXComboBox.o ./FXComposeContext.o ./FXComposite.o ./FXCursor.o ./FXDC.o ./FXDCPrint.o ./FXDCWindow.o ./FXDLL.o ./FXDataTarget.o ./FXDate.o ./FXDebugTarget.o ./FXDelegator.o ./FXDial.o ./FXDialogBox.o ./FXDict.o ./FXDir.o ./FXDirBox.o ./FXDirDialog.o ./FXDirList.o ./FXDirSelector.o ./FXDockBar.o ./FXDockHandler.o ./FXDockSite.o ./FXDockTitle.o ./FXDocument.o ./FXDragCorner.o ./FXDrawable.o ./FXDriveBox.o ./FXException.o ./FXExpression.o ./FXExtentd.o ./FXExtentf.o ./FXFile.o ./FXFileDialog.o ./FXFileDict.o ./FXFileList.o ./FXFileSelector.o ./FXFileStream.o ./FXFoldingList.o ./FXFont.o ./FXFontDialog.o ./FXFontSelector.o ./FXFrame.o ./FXGIFCursor.o ./FXGIFIcon.o ./FXGIFImage.o ./FXGLCanvas.o ./FXGLCone.o ./FXGLContext.o ./FXGLCube.o ./FXGLCylinder.o ./FXGLObject.o ./FXGLShape.o ./FXGLSphere.o ./FXGLTriangleMesh.o ./FXGLViewer.o ./FXGLVisual.o ./FXGUISignal.o ./FXGZFileStream.o ./FXGradientBar.o ./FXGroupBox.o ./FXHash.o ./FXHeader.o ./FXHorizontalFrame.o ./FXICOIcon.o ./FXICOImage.o ./FXIFFIcon.o ./FXIFFImage.o ./FXIO.o ./FXIcon.o ./FXIconDict.o ./FXIconList.o ./FXIconSource.o ./FXId.o ./FXImage.o ./FXImageFrame.o ./FXImageView.o ./FXInputDialog.o ./FXJPGIcon.o ./FXJPGImage.o ./FXKOI8RCodec.o ./FXKnob.o ./FXLabel.o ./FXList.o ./FXListBox.o ./FXMDIButton.o ./FXMDIChild.o ./FXMDIClient.o ./FXMainWindow.o ./FXMat3d.o ./FXMat3f.o ./FXMat4d.o ./FXMat4f.o ./FXMatrix.o ./FXMemMap.o ./FXMemoryStream.o ./FXMenuBar.o ./FXMenuButton.o ./FXMenuCaption.o ./FXMenuCascade.o ./FXMenuCheck.o ./FXMenuCommand.o ./FXMenuPane.o ./FXMenuRadio.o ./FXMenuSeparator.o ./FXMenuTitle.o ./FXMessageBox.o ./FXObject.o ./FXObjectList.o ./FXOptionMenu.o ./FXPCXIcon.o ./FXPCXImage.o ./FXPNGIcon.o ./FXPNGImage.o ./FXPPMIcon.o ./FXPPMImage.o ./FXPacker.o ./FXPath.o ./FXPicker.o ./FXPipe.o ./FXPoint.o ./FXPopup.o ./FXPrintDialog.o ./FXProgressBar.o ./FXProgressDialog.o ./FXQuatd.o ./FXQuatf.o ./FXRASIcon.o ./FXRASImage.o ./FXRGBIcon.o ./FXRGBImage.o ./FXRadioButton.o ./FXRanged.o ./FXRangef.o ./FXRealSlider.o ./FXRealSpinner.o ./FXRecentFiles.o ./FXRectangle.o ./FXRegion.o ./FXRegistry.o ./FXReplaceDialog.o ./FXRex.o ./FXRootWindow.o ./FXRuler.o ./FXRulerView.o ./FXScrollArea.o ./FXScrollBar.o ./FXScrollPane.o ./FXScrollWindow.o ./FXSearchDialog.o ./FXSeparator.o ./FXSettings.o ./FXShell.o ./FXShutter.o ./FXSize.o ./FXSlider.o ./FXSocket.o ./FXSphered.o ./FXSpheref.o ./FXSpinner.o ./FXSplashWindow.o ./FXSplitter.o ./FXSpring.o ./FXStat.o ./FXStatusBar.o ./FXStatusLine.o ./FXStream.o ./FXString.o ./FXStringDict.o ./FXSwitcher.o ./FXSystem.o ./FXTGAIcon.o ./FXTGAImage.o ./FXTIFIcon.o ./FXTIFImage.o ./FXTabBar.o ./FXTabBook.o ./FXTabItem.o ./FXTable.o ./FXText.o ./FXTextCodec.o ./FXTextField.o ./FXThread.o ./FXToggleButton.o ./FXToolBar.o ./FXToolBarGrip.o ./FXToolBarShell.o ./FXToolBarTab.o ./FXToolTip.o ./FXTopWindow.o ./FXTranslator.o ./FXTreeList.o ./FXTreeListBox.o ./FXTriStateButton.o ./FXURL.o ./FXUTF16Codec.o ./FXUTF32Codec.o ./FXUTF8Codec.o ./FXUndoList.o ./FXVec2d.o ./FXVec2f.o ./FXVec3d.o ./FXVec3f.o ./FXVec4d.o ./FXVec4f.o ./FXVerticalFrame.o ./FXVisual.o ./FXWindow.o ./FXWizard.o ./FXXBMIcon.o ./FXXBMImage.o ./FXXPMIcon.o ./FXXPMImage.o ./fxascii.o ./fxbmpio.o ./fxezquantize.o ./fxfilematch.o ./fxfsquantize.o ./fxgifio.o ./fxicoio.o ./fxiffio.o ./fxjpegio.o ./fxkeyboard.o ./fxkeysym.o ./fxparsegeometry.o ./fxpcxio.o ./fxpngio.o ./fxppmio.o ./fxpriv.o ./fxpsio.o ./fxrasio.o ./fxrgbio.o ./fxtargaio.o ./fxtifio.o ./fxunicode.o ./fxutils.o ./fxwuquantize.o ./fxxbmio.o ./fxxpmio.o ./icons.o ./strtoll.o ./vsscanf.o   -lX11 -lXft -lpng -lGL -lGLU -lXrender -lXext -lrt -lpthread
/usr/bin/ld: skipping incompatible /usr/lib32/libX11.so when searching for -lX11
/usr/bin/ld: skipping incompatible /usr/lib32/libX11.a when searching for -lX11
/usr/bin/ld: skipping incompatible /usr/lib32/libpng.so when searching for -lpng
/usr/bin/ld: skipping incompatible /usr/lib32/libpng.a when searching for -lpng
/usr/bin/ld: skipping incompatible /usr/lib32/libGL.so when searching for -lGL
/usr/bin/ld: skipping incompatible /usr/lib32/libGLU.so when searching for -lGLU
/usr/bin/ld: skipping incompatible /usr/lib32/libGLU.a when searching for -lGLU
Finished building target: libFOX.so
/usr/bin/ld: skipping incompatible /usr/lib32/libXrender.so when searching for -lXrender
/usr/bin/ld: skipping incompatible /usr/lib32/libXrender.a when searching for -lXrender
/usr/bin/ld: skipping incompatible /usr/lib32/libXext.so when searching for -lXext
/usr/bin/ld: skipping incompatible /usr/lib32/libXext.a when searching for -lXext
/usr/bin/ld: skipping incompatible /usr/lib32/librt.so when searching for -lrt
/usr/bin/ld: skipping incompatible /usr/lib32/librt.a when searching for -lrt
/usr/bin/ld: skipping incompatible /usr/lib32/libpthread.so when searching for -lpthread
/usr/bin/ld: skipping incompatible /usr/lib32/libpthread.a when searching for -lpthread
/usr/bin/ld: skipping incompatible /usr/lib32/libm.so when searching for -lm
/usr/bin/ld: skipping incompatible /usr/lib32/libm.a when searching for -lm
/usr/bin/ld: skipping incompatible /usr/lib32/libc.so when searching for -lc
/usr/bin/ld: skipping incompatible /usr/lib32/libc.a when searching for -lc
Logic errors! It is trying to link 32bits libraries to FOX which has just been compiled in 64bit.
But why does not it respect this path when i try to compile FOX in 32bit.
I dont understand anything anymore.. ldconfig problem?
[Updated on: Tue, 17 July 2012 11:05]
Report message to a moderator
Re: Compilation 32bit on 64bit plateform (advenced) [message #896174 is a reply to message #896119] Tue, 17 July 2012 13:46 Go to previous messageGo to next message
It works when i compile in the term :
root@solinnen:~/Documents/testfox# g++-4.4 -m32 *.cpp -I /usr/local/include/fox-1.6/ -L ../FOX/Debug/ -lFOX -L /usr/lib32/ /usr/lib32/libXft.so.2
But i do not understand, if someone can explain to me?
Now how can i do this compilation in Eclipse?
[Updated on: Tue, 17 July 2012 13:47]
Re: Compilation 32bit on 64bit plateform (advenced) [message #896367 is a reply to message #896174] Wed, 18 July 2012 08:13 Go to previous messageGo to next message
That's weird. It should search in /usr/lib/gcc/i686-linux-gnu/4.4.5/../../../
Did you call "make clean" after adding the "-m32" option? Perhaps there are some leftovers.
Gary All wrote on Tue, 17 July 2012 15:46
In this case you explicitly name the Xft library to use for linking (remember: -L is usually for the library path). You can user this approach in Eclipse, too. You have to tweak the settings C/C++ Build->Settings->Linker settings
Before you ask
- search this forum
- google
Re: Compilation 32bit on 64bit plateform (advenced) [message #896391 is a reply to message #896367] Wed, 18 July 2012 09:15 Go to previous messageGo to next message
It works. I add /usr/lib32/ in FOX properties/C++build/settings/C++linker/libraries/library search path(-L) but i can not add /usr/lib32/libXft.so.2 in FOX properties/C++build/settings/C++linker/libraries/libraries(-l).
So i add it in FOX properties/C++build/settings/C++linker/Miscellaneous/other object
I find it dirty but it works.
Now i export my 32but application on my 32bit Debian:
./exe: error while loading shared libraries: libFOX.so: cannot open shared object file: No such file or directory.
Fox is a shared library because only with shared librares you have the option C++linker in properies if not how link others libraries (-lX11, -lXft, -lGLU) to a static library?
Re: Compilation 32bit on 64bit plateform (advenced) [message #896683 is a reply to message #896391] Thu, 19 July 2012 11:35 Go to previous message
Gary All wrote on Wed, 18 July 2012 11:15
What does ldd print out? Is libFOX.so in your /lib directory?
Before you ask
- search this forum
- google
Previous Topic:Eclipse CDT - display freeze on ubuntu
Next Topic:Obtaining call hierarchy
Current Time: Tue Feb 20 14:02:36 GMT 2018
Powered by FUDForum. Page generated in 0.01919 seconds
