Home » Modeling » ATL » ATL Execution Error
ATL Execution Error [message #894682] Tue, 10 July 2012 02:56 Go to next message
noi poi is currently offline noi poi
Hey there !
i am installed the TextBe plugin
Now the plugin was working fine until i installed ATL SDK in it and after that whenever i try editing in the TextBe plugin it gives me ATL execution error.
I installed the ATL from sdk download.eclipse.org/releases/ganymede site
. Here is the error log. How can i fix it
!SUBENTRY 1 org.be.textbe.beviz.be2gv.builder 4 75 2012-07-05 04:06:23.553
!MESSAGE Errors running builder 'BE Project Builder' on project 'org.be.textbe.bt.examples.microwave_oven'.
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/m2m/atl/common/ATLExecutionException
at org.be.textbe.beviz.be2gv.builder.builder.BeBuilder.transformBe2Gv(BeBuilder.java:123)
at org.be.textbe.beviz.be2gv.builder.builder.BeBuilder.transformBe2GvNoParams(BeBuilder.java:79)
at org.be.textbe.beviz.be2gv.builder.builder.BeBuilder$BeResourceVisitor.visit(BeBuilder.java:66)
at org.eclipse.core.internal.resources.Resource$2.visit(Resource.java:106)
at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:65)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:75)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:104)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:88)
at org.be.textbe.beviz.be2gv.builder.builder.BeBuilder.fullBuild(BeBuilder.java:197)
at org.be.textbe.beviz.be2gv.builder.builder.BeBuilder.build(BeBuilder.java:103)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.ClassNotFoundException: org.eclipse.m2m.atl.common.ATLExecutionException
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
... 26 more
!SESSION 2012-07-05 08:40:28.127 -----------------------------------------------
Naurin
Re: ATL Execution Error [message #894757 is a reply to message #894682] Tue, 10 July 2012 07:52 Go to previous message
This looks like a Java class compatibility problem.
Firstly refresh all your projects and rebuild everything since it may
just be an inaccurate incremental build problem.
If the problem persists, then you have probably used a mix of Eclipse
versions. Make sure you use all Indigo, or all Juno.
Ed Willink
On 10/07/2012 07:56, noi poi wrote:
> Hey there !
> execution error.
> site Here is the error log. How can i fix it
> 04:06:23.553
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 26 more
> Naurin
Previous Topic:ATL transformation
Next Topic:[ATL] Unresolved cross-reference... Again
Current Time: Thu May 23 19:32:32 EDT 2013
Powered by FUDForum. Page generated in 0.01561 seconds
