Home » Modeling » ATL » ATL plugin using UML metamodel
ATL plugin using UML metamodel [message #887556] Sat, 16 June 2012 20:52
Fernanda R.F. is currently offline Fernanda R.F.Friend
Member
I'm trying to use ATL plugin, but I'm getting the following error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Could not find model element Model from UML
Java Stack:
	at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM.java:243)
	at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:195)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
	at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch(EMFVMLauncher.java:139)
	at uml2metamodelRC.Uml2metamodel.doUml2metamodel(Uml2metamodel.java:165)
	at uml2metamodelRC.Uml2metamodel.main(Uml2metamodel.java:80)
Caused by: org.eclipse.m2m.atl.engine.emfvm.ASM$SignatureParsingException: Could not find model element Model from UML
	at org.eclipse.m2m.atl.engine.emfvm.ASM.parseTypeInternal(ASM.java:414)
	at org.eclipse.m2m.atl.engine.emfvm.ASM.parseType(ASM.java:378)
	at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM.java:240)
	... 5 more
I'm using an UML file as metamodel in and an Ecore file as metamodel out.
I tried change sending a URL instead of UML metamodel, however the error still occurring.
So, what could I do to resolve it?
Previous Topic:Sources for EMFTVM
Next Topic:Applying UML profile for target model using ATL
Current Time: Sat Feb 24 03:02:25 GMT 2018
Powered by FUDForum. Page generated in 0.02077 seconds
