Home » Eclipse Projects » BIRT » API: setProperty() with Type
API: setProperty() with Type [message #884613] Mon, 11 June 2012 13:30 Go to next message
Chris K is currently offline Chris KFriend
Hi there!
I am trying to create the following output using the BIRT 3.7.2 API:
<image id="570">
<property name="height">6.25in</property>
<property name="width">6.25in</property>
<property name="source">url</property>
<expression name="uri" type="constant">file:///D:/myfiles/chart_20120611143249773.jpg</expression>
</image>
In my method I use
ImageHandle image = factory.newImage(null);
image.setFile(obj.getUrl());
image.setProperty("source", "url");
image.setWidth(obj.getWidth() + "px");
image.setHeight(obj.getHeight() + "px");
but all I get is
<image id="77">
<property name="height">201px</property>
<property name="width">222px</property>
<expression name="uri">file:///D:\myfiles\chart_20120611152309989.jpg</expression>
</image>
What I need is to add the type="constant" to the XML-output. Otherwise BIRT won't render the PDF, saying missing ; before statement (<inline>#1). How can I achieve this using the API?
Thanks in advance!
Chris
In case you need the exception, this is what BIRT throws with missing type="constant":
org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1107)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:935)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at sun.reflect.GeneratedMethodAccessor66.invoke(Unknown Source)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2248)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:190)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
... 47 more
Caused by: org.mozilla.javascript.EvaluatorException: Unexpected end of file (#1)
at org.mozilla.javascript.DefaultErrorReporter.runtimeError(DefaultErrorReporter.java:109)
at org.mozilla.javascript.DefaultErrorReporter.error(DefaultErrorReporter.java:96)
at org.mozilla.javascript.Parser.addError(Parser.java:146)
at org.mozilla.javascript.Parser.reportError(Parser.java:160)
at org.mozilla.javascript.Parser.primaryExpr(Parser.java:2465)
at org.mozilla.javascript.Parser.memberExpr(Parser.java:1955)
at org.mozilla.javascript.Parser.unaryExpr(Parser.java:1813)
at org.mozilla.javascript.Parser.mulExpr(Parser.java:1742)
at org.mozilla.javascript.Parser.addExpr(Parser.java:1723)
at org.mozilla.javascript.Parser.shiftExpr(Parser.java:1703)
at org.mozilla.javascript.Parser.relExpr(Parser.java:1677)
at org.mozilla.javascript.Parser.eqExpr(Parser.java:1633)
at org.mozilla.javascript.Parser.bitAndExpr(Parser.java:1622)
at org.mozilla.javascript.Parser.bitXorExpr(Parser.java:1611)
at org.mozilla.javascript.Parser.bitOrExpr(Parser.java:1600)
at org.mozilla.javascript.Parser.andExpr(Parser.java:1588)
at org.mozilla.javascript.Parser.orExpr(Parser.java:1576)
at org.mozilla.javascript.Parser.condExpr(Parser.java:1559)
at org.mozilla.javascript.Parser.assignExpr(Parser.java:1544)
at org.mozilla.javascript.Parser.expr(Parser.java:1523)
at org.mozilla.javascript.Parser.statementHelper(Parser.java:1246)
at org.mozilla.javascript.Parser.statementHelper(Parser.java:1232)
at org.mozilla.javascript.Parser.statement(Parser.java:707)
at org.mozilla.javascript.Parser.parse(Parser.java:401)
at org.mozilla.javascript.Parser.parse(Parser.java:338)
at org.mozilla.javascript.Context.compileImpl(Context.java:2368)
at org.mozilla.javascript.Context.compileString(Context.java:1359)
at org.mozilla.javascript.Context.compileString(Context.java:1348)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine$3.run(JavascriptEngine.java:240)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine$3.run(JavascriptEngine.java:1)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.compile(JavascriptEngine.java:236)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.compile(JavascriptEngine.java:1)
at org.eclipse.birt.core.script.ScriptContext.compile(ScriptContext.java:148)
at org.eclipse.birt.report.engine.executor.ExecutionContext.compile(ExecutionContext.java:771)
at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:705)
at org.eclipse.birt.report.engine.executor.ReportItemExecutor.evaluateString(ReportItemExecutor.java:297)
at org.eclipse.birt.report.engine.executor.ImageItemExecutor.handleURIImage(ImageItemExecutor.java:261)
at org.eclipse.birt.report.engine.executor.ImageItemExecutor.handleImage(ImageItemExecutor.java:214)
at org.eclipse.birt.report.engine.executor.ImageItemExecutor.execute(ImageItemExecutor.java:111)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
... 49 more
Re: API: setProperty() with Type [message #884708 is a reply to message #884613] Mon, 11 June 2012 16:30 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Try using the org.eclipse.birt.report.model.api.Expression class
ImageHandle image1 = designFactory.newImage( "eclipseimage" );
Expression myexpression = new Expression(
"http://www.eclipse.org/eclipse.org-common/themes/Nova/images/eclipse.png",
ExpressionType.CONSTANT );
image1.setSource("url");
image1.setExpressionProperty("uri", myexpression);
Jason
On 6/11/2012 9:30 AM, Chris K wrote:
> Hi there!
> <image id="570">
> </image>
> In my method I use
> but all I get is
> <image id="77">
> <expression
> </image>
> Thanks in advance!
> Chris
> type="constant":
> Quote:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 47 more
>> of file (#1)
>> at
>> at
>> at
>> at
>> at java.security.AccessController.doPrivileged(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 49 more
Re: API: setProperty() with Type [message #885012 is a reply to message #884708] Tue, 12 June 2012 09:13 Go to previous message
Thanks Jason, this one worked!
Chris
Previous Topic:Debugging BIRT Source (2.6.0)
Next Topic:org.eclipse.birt.core.archive.FolderArchive Example?
Current Time: Sat Feb 17 19:53:16 GMT 2018
Powered by FUDForum. Page generated in 0.02160 seconds
