Home » Modeling » ATL » Sources for EMFTVM
Sources for EMFTVM [message #883039] Thu, 07 June 2012 13:55 Go to next message
Alain Picard is currently offline Alain Picard
In the latest RC2 I don't see the source for EMFTVM.
Is it missing?
Alain
Re: Sources for EMFTVM [message #883924 is a reply to message #883039] Sat, 09 June 2012 14:42 Go to previous messageGo to next message
Dennis Wagelaar is currently offline Dennis Wagelaar
> Is it missing?
> Thanks
> Alain
Indeed, it's missing. I think it's a release engineering issue. William, can
you comment? Source code is very useful to have when developing against EMFTVM
API, or when finding bugs in EMFTVM.
Dennis
Re: Sources for EMFTVM [message #884512 is a reply to message #883924] Mon, 11 June 2012 04:23 Go to previous messageGo to next message
William Piers is currently offline William Piers
The modification is quite simple, but unfortunately at this time of the
release I won't be able to integrate the source. This will be done for
ATL 3.3.1.
Could you please open a bugzilla entry about this ? Thanks in advance.
William
>> Is it missing?
>> Thanks
>> Alain
> Dennis
Re: Sources for EMFTVM [message #886381 is a reply to message #884512] Thu, 14 June 2012 16:30 Go to previous message
Op 11-06-12 10:23, William Piers schreef:
> release I won't be able to integrate the source. This will be done for ATL 3.3.1.
> William
Done. If you need source code included in the mean time, you may use the
private builds I make myself at http://soft.vub.ac.be/eclipse/update-3.7/
Dennis
Previous Topic:[ATL] Invoking an ATL transformation on a part of a model, not on a whole model
Next Topic:ATL plugin using UML metamodel
Current Time: Wed May 22 17:53:56 EDT 2013
Powered by FUDForum. Page generated in 0.01579 seconds
