Home » Modeling » ATL » BPEL 2 XML using ATL
BPEL 2 XML using ATL [message #882024] Tue, 05 June 2012 12:44
nemaetf@gmail.com nema is currently offline nemaetf@gmail.com nema
I'm trying to establish a transformation between BPEL to XML.
I have two metamodels:
- bpel.ecore
- XML.ecore
The ATL code is:
module BPEL2XML;
create OUT : XML from IN : BPEL;
rule Process2Root{
	from
	  s : BPEL!Process
	to
	  	t : XML!Root(
	  	 name <- 'process',
	  	 children <- Sequence{xmlns, name, tgnsp, s.partnerLinks,
	  	                s.variables, s.scopeElementActivity}
	  	xmlns : XML!Attribute(
	  	name <- 'xmlns',
	  	value <- 'Z'
	  	 name <- 'name',
	  	 value <- s.name ),
	  	tgnsp : XML!Attribute(
	 	  name <- 'targetNamespace',
		   value <- s.targetNameSpace
	do
		s.debug('bpel2xml applied');
However, no transformation is done and I get errors like this:
Metamodel contains several classifiers with same name: ecore::EByte
Metamodel contains several classifiers with same name: EByteArray
Metamodel contains several classifiers with same name: ecore::EByteArray
Metamodel contains several classifiers with same name: EByteObject
Metamodel contains several classifiers with same name: ecore::EByteObject
Metamodel contains several classifiers with same name: EChar
Metamodel contains several classifiers with same name: ecore::EChar
Metamodel contains several classifiers with same name: ECharacterObject
Metamodel contains several classifiers with same name: ecore::ECharacterObject
Metamodel contains several classifiers with same name: EDate
Metamodel contains several classifiers with same name: ecore::EDate
Metamodel contains several classifiers with same name: EDiagnosticChain
Metamodel contains several classifiers with same name: ecore::EDiagnosticChain
Metamodel contains several classifiers with same name: EDouble
Metamodel contains several classifiers with same name: ecore::EDouble
Metamodel contains several classifiers with same name: EDoubleObject
Metamodel contains several classifiers with same name: ecore::EDoubleObject
Metamodel contains several classifiers with same name: EEList
Metamodel contains several classifiers with same name: ecore::EEList
Metamodel contains several classifiers with same name: EEnumerator
Metamodel contains several classifiers with same name: ecore::EEnumerator
Metamodel contains several classifiers with same name: EFeatureMap
Metamodel contains several classifiers with same name: ecore::EFeatureMap
Metamodel contains several classifiers with same name: EFeatureMapEntry
Metamodel contains several classifiers with same name: ecore::EFeatureMapEntry
Metamodel contains several classifiers with same name: EFloat
Metamodel contains several classifiers with same name: ecore::EFloat
Metamodel contains several classifiers with same name: EFloatObject
Metamodel contains several classifiers with same name: ecore::EFloatObject
Metamodel contains several classifiers with same name: EInt
Metamodel contains several classifiers with same name: ecore::EInt
Metamodel contains several classifiers with same name: EIntegerObject
Metamodel contains several classifiers with same name: ecore::EIntegerObject
Metamodel contains several classifiers with same name: EJavaClass
Metamodel contains several classifiers with same name: ecore::EJavaClass
Metamodel contains several classifiers with same name: EJavaObject
Metamodel contains several classifiers with same name: ecore::EJavaObject
Metamodel contains several classifiers with same name: ELong
Metamodel contains several classifiers with same name: ecore::ELong
Metamodel contains several classifiers with same name: ELongObject
Metamodel contains several classifiers with same name: ecore::ELongObject
Metamodel contains several classifiers with same name: EMap
Metamodel contains several classifiers with same name: ecore::EMap
Metamodel contains several classifiers with same name: EResource
Metamodel contains several classifiers with same name: ecore::EResource
Metamodel contains several classifiers with same name: EResourceSet
Metamodel contains several classifiers with same name: ecore::EResourceSet
Metamodel contains several classifiers with same name: EShort
Metamodel contains several classifiers with same name: ecore::EShort
Metamodel contains several classifiers with same name: EShortObject
Metamodel contains several classifiers with same name: ecore::EShortObject
Metamodel contains several classifiers with same name: EString
Metamodel contains several classifiers with same name: ecore::EString
Metamodel contains several classifiers with same name: ETreeIterator
Metamodel contains several classifiers with same name: ecore::ETreeIterator
Metamodel contains several classifiers with same name: EInvocationTargetException
Metamodel contains several classifiers with same name: ecore::EInvocationTargetException
Metamodel contains several classifiers with same name: Import
Metamodel contains several classifiers with same name: ExtensibleElement
Thx in advance for your help.
[Updated on: Tue, 05 June 2012 12:50]
Report message to a moderator
Previous Topic:Ecore 2 Ecore using ATL ->output java objects
Next Topic:How to improve my ATL transformation
Current Time: Wed May 22 20:48:12 EDT 2013
Powered by FUDForum. Page generated in 0.01425 seconds
